- The pixel colors are not displaying correctly on most modes and presets. for example,
Stun in the NN-14 config displays white/pink where as the fire mode displays blue barrel with a yellow muzzel pixel. The animations for these work.
The A-180 full auto mode flashes pink and then on release, fades from off to max brightness of pink and then shuts off at the end of the wav file.
I loaded on a different blasters config that had the same results on this blaster. Most of the bladestyles are the same in the configs, only the order of the presets change mostly or I add new presets as i create new fonts for new blasters.
The “working” config that i used to confirm everything was wired correctly and working as intended
#define NUM_BLADES 3
#define VOLUME 2500
#define CLASH_THRESHOLD_G 4.0
#define ENABLE_SSD1306
#define SAVE_STATE
#define FETT263_TWIST_ON
#define FETT263_RANDOMIZE_QUOTE_PLAYER
{ "Halcyon;common", "/Halcyon/tracks",
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,White>>,TrFade<1200>>,EFFECT_IGNITION>,
TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,DarkOrange>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,7992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,20992>,Int<98304>>>>>>>(),
StylePtr<Layers<
TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Int<0>>,EFFECT_BLAST>,
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,SmoothStep<ClashImpactF<>,Int<-4000>>>,TrFadeX<Scale<ClashImpactF<>,Int<100>,Int<300>>>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Int<0>>,TrSparkX<Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Int<0>>>>,EFFECT_LOCKUP_END>,
LockupTrL<AlphaL<RgbArg<LB_COLOR_ARG,White>,Int<0>>,TrInstant,TrConcat<TrInstant,Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrFade<1000>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,8000>>>>(),
StylePtr<Layers<
"halcyon"},
{ "Scavenger;common", "/Scavenger/tracks",
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,White>,40>,TrFade<1200>>,EFFECT_IGNITION>,
LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,White>,TrFade<400>>>,
LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,20992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,6992>,Int<98304>>>>>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<100>>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrWipe<100>,AlphaL<DodgerBlue,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrDelayX<Sum<WavLen<EFFECT_PREON>,Int<200>>>>,EFFECT_PREON>>>(),
StylePtr<Layers<
LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<255,140,0>>,8000>>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<100>>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<PREON_SIZE_ARG,32768>,Int<-2000>>>,TrWipe<100>,AlphaL<DodgerBlue,SmoothStep<IntArg<PREON_SIZE_ARG,32768>,Int<-2000>>>,TrDelayX<Sum<WavLen<EFFECT_PREON>,Int<200>>>>,EFFECT_PREON>>>(),
StylePtr<Layers<
"scavenger"},
{ "Kylo;common", "/Kylo/tracks",
StylePtr<Layers<
StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Red>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,Red>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Red>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Red>>,0,6,10,1000,2>,
AlphaL<RandomPerLEDFlickerL<RgbArg<EMITTER_COLOR_ARG,White>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,1500>,Int<6000>>>,Int<-6000>>>,
SparkleL<BrownNoiseFlickerL<White,Int<50>>,30,1500>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,17992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,5992>,Int<98304>>>>>>>(),
StylePtr<Layers<
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Red>,8000>>,
StylePtr<Layers<
"kylo ren"},
{ "Sorcerer;common", "/Sorcerer/tracks",
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,5992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,6992>,Int<98304>>>>>>>(),
StylePtr<Layers<
InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>,8000>>>>(),
StylePtr<Layers<
"sorcerer"},
//main blade
{ 0, WS281XBladePtr<1, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
//crystal
WS281XBladePtr<10, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
WS281XBladePtr<10, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
CONFIGARRAY(presets) },
- Arduino-proffie 4.1
