so I redid the config and I’m getting this error.
Arduino: 1.8.19 (Linux), Board: "Proffieboard V2, Serial, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from /home/maxb/Documents/ProffieOS/ProffieOS.ino:563:
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: template argument 1 is invalid
91 | StylePtr<Layers<Mix<IncrementWithReset<ThresholdPulseF<SwingSpeed<400>,Int<18000>>,EffectPulseF<EFFECT_IGNITION>,Int<32768>,Int<3277>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,255>>>,AudioFlicker<Stripes<24000,-1400,RgbArg<ALT_COLOR_ARG,Rgb<85,85,200>>,RgbArg<ALT_COLOR_ARG,Rgb<85,85,200>>,Mix<Int<11565>,Black,RgbArg<ALT_COLOR_ARG,Rgb<85,85,200>>>,RgbArg<ALT_COLOR_ARG,Rgb<85,85,200>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<85,85,200>>>>,RgbArg<ALT_COLOR_ARG,Rgb<85,85,200>>>>,ColorSelect<IntArg<SWING_OPTION_ARG,0>,TrInstant,AlphaL<Black,Int<0>>,ColorSelect<IncrementF<EffectPulseF<EFFECT_FORCE>,Int<32000>,Int<2>>,TrSmoothFade<500>,AlphaL<RgbArg<BASE_COLOR_ARG,Red>,Int<0>>,AlphaL<StripesX<Int<10000>,Scale<IncrementWithReset<ThresholdPulseF<Ifon<StrobeF<Int<12>,Int<1>>,Int<0>>,Int<32000>>,ThresholdPulseF<Sum<ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<33000>>>,Int<0>>,Int<24000>>,EffectPulseF<EFFECT_FORCE>>,Int<32000>>,Int<10000>,Int<100>>,Int<-50>,Int<-8000>>,Mix<Int<10000>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<20000>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<Sum<IncrementWithReset<ThresholdPulseF<StrobeF<Int<10>,Int<1>>,Int<30000>>,ThresholdPulseF<Sum<ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<38000>>>,Int<0>>,Int<16000>>,EffectPulseF<EFFECT_FORCE>>,Int<32000>>,Int<4000>,Int<100>>,IncrementWithReset<ThresholdPulseF<Ifon<HoldPeakF<SwingSpeed<400>,Int<100>,Int<33000>>,Int<0>>,Int<16000>>,ThresholdPulseF<Sum<ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<38000>>>,Int<0>>,Int<16000>>,EffectPulseF<EFFECT_FORCE>>,Int<32000>>,Int<38000>,Int<38000>>>,Int<-2000>>>>,AlphaL<StripesX<Int<10000>,Scale<IncrementWithReset<ThresholdPulseF<Ifon<StrobeF<Int<12>,Int<1>>,Int<0>>,Int<32000>>,ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<33000>>>,Int<0>>,Int<24000>>,Int<10000>,Int<100>>,Int<-50>,Int<-8000>>,Mix<Int<10000>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<20000>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<Sum<IncrementWithReset<ThresholdPulseF<StrobeF<Int<10>,Int<1>>,Int<30000>>,ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<38000>>>,Int<0>>,Int<16000>>,Int<4000>,Int<100>>,IncrementWithReset<ThresholdPulseF<Ifon<HoldPeakF<SwingSpeed<400>,Int<100>,Int<33000>>,Int<0>>,Int<16000>>,ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<38000>>>,Int<0>>,Int<16000>>,Int<38000>,Int<38000>>>,Int<-2000>>>>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrInstant,TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<1200>>>,EFFECT_IGNITION>,TransitionEffectL<TrSelect<IntArg<RETRACTION_COOL_DOWN_ARG,0>,TrInstant,TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>>,EFFECT_RETRACTION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<IgnitionTime<300>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,IgnitionTime<300>,Mult<IgnitionTime<300>,Int<16384>>>>,TrConcat<TrJoin<TrDelay<10000>,TrInstant>,AlphaL<Black,SmoothStep<IncrementWithReset<ThresholdPulseF<SwingSpeed<400>,Int<18000>>,EffectPulseF<EFFECT_IGNITION>,Int<33000>,Int<11000>>,Int<0>>>,TrWipeX<IgnitionTime<300>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<RetractionTime<0>,Int<16384>>,RetractionTime<0>>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<4000>>>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<Red,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<Orange,15>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-3000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<White,20>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>>,TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>>,EFFECT_PREON>,TransitionEffectL<TrSelect<IntArg<OFF_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrJoin<TrDelayX<;Int<500>>,TrFade<500>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<500>>,TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>>>(),
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: template argument 3 is invalid
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: template argument 4 is invalid
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: wrong number of template arguments (1, should be 2)
In file included from /home/maxb/Documents/ProffieOS/ProffieOS.ino:459:
/home/maxb/Documents/ProffieOS/styles/transition_effect.h:17:7: note: provided for 'template<class TRANSITION, EffectType EFFECT> class TransitionEffectL'
17 | class TransitionEffectL {
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: template argument 13 is invalid
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91:1: error: parse error in template argument list
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: expected '}' before ';' token
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:59:1: note: to match this '{'
59 | {"Bal Venos;common", "common/tracks/20thCentFanfare.wav",
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:56:20: note: to match this '{'
56 | Preset presets[] = {
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: cannot resolve overloaded function 'StylePtr' based on conversion to type 'StyleFactory*'
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:91: error: expected unqualified-id before '>' token
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:93:1: error: expected declaration before '}' token
93 | },
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:93:2: error: expected unqualified-id before ',' token
93 | },
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:94:1: error: expected unqualified-id before '}' token
94 | };
/home/maxb/Documents/ProffieOS/config/Proffiev6_7.h:94:1: error: expected declaration before '}' token
