Idea: Crystal bleeding button combination (prop), blade style and sound effects
Hey, I was playing Jedi Survivor and I saw Dagan Gera bleeding his Crystal. So I thought would it not be cool to have another prop which includes a button combination to bleed the crystal from color 1 to color 2 (red i.e). accompanied by special “bleeding” sound effects.
Is there already such a thing? I couldn’t find anything here.
If this is really new, I will try to go deeper into topic. Suggestions are welcomed.
BR
You mean this?
My prop already handles via Special Ability controls. Just generate the style via my library and set up font from instructions with style code.
Yes, exactly! That’s crazy. I would like it to be more “explosive” like in Jedi Survivor but I think I can do it easily with your Prop and some work with the Soundfont and Blade Styles.
Again, thanks! The prop does exactly what I want. If I have some troubles I will respond again. I have many projects atm but I will post once its done.
BR
If you don’t want the slow Corruption effect, just set up a normal “Multi-Phase (Special Abilities)” style and choose the Transition animation and timing you want, then set up Phase controls in Special Abilities as you see fit. There’s infinite ways to customize the effect, just watch the videos at the top of the library and set up the style to your taste, Special Abilities are highly customizable :wink:
There’s also the whole Party Mode functionality from the last game as well, there’s a ton of options for Phase changing in the library.
