I need help with my config, i keep getting errors about beepers and talkies
I keep getting 20+ orange lines of errors with my luke v2 proffie, this is the THIRD reconfiguration of the board ive done, and this time im using fett263’s new using functions to have multiple rotoscope styles. I followed along with his video on it but im just having a rough time.
here is my full config:
// ProffieOS7 Config File
#define NUM_BUTTONS 1
#define EXTRA_COLOR_BUFFER_SPACE 40
#define VOLUME 1850
#define CLASH_THRESHOLD_G 1
#define IDLE_OFF_TIME 60 * 3 * 1000
#define DISABLE_TALKIE
#define BLADE_DETECT_PIN blade4Pin
#define FETT263_TRACK_PLAYER_NO_PROMPTS
#define FETT263_USE_BC_MELT_STAB
{ "Luke_Training;common",  "Tracks/luketraining.wav",
StylePtr<MainRotoscope>("0,16174,65535 ~ 4"),
"Luke_Training"
{ "Luke;common",  "Tracks/luke.wav",
StylePtr<MainRotoscope>("0,65535,0 ~ 1"),
"Luke"
{ "Hoth;common",  "Tracks/hoth.wav",
StylePtr<MainRotoscope>("5845,5845,38402 ~ 2"),
"Hoth"
{ "Ben;common",  "Tracks/obiwan.wav",
StylePtr<MainRotoscope>("0,0,65535"),
"Ben"
{ "Darth;common",  "Tracks/vader.wav",
StylePtr<MainRotoscope>("65535,0,0 ~ ~ ~ 650"),
"Darth"
{ "Third;common",  "tracks/vodean.wav",
StylePtr<MainRotoscope>("65535,0,0"),
"Third"
{ "Grumpy_Uncle_V2;common",  "Tracks/oldluke.wav",
StylePtr<MainRotoscope>("0,65535,0"),
"Grumpy_Uncle_V2"
{ "Krossguard;common",  "Tracks/kylo.wav",
StylePtr<MainUnstable>("65535,0,0"),
"Krossguard"
{ "QuisGone;common",  "Tracks/rebelsmusic2.wav",
"QuisGone"
{ "Shatterpoint;common",  "Tracks/thunderstorm.wav",
StylePtr<MainRotoscope>("11366,128,57353"),
"Shatterpoint"
{ "Blind_Cowboy;common",  "Tracks/rebelsmusic1.wav",
"Blind_Cowboy"
{ "Loth_Hero;common",  "Tracks/rebelsmusic3.wav",
"Loth_Hero"
{ "Malign;common",  "Tracks/templemarch.wav",
StylePtr<MainUnstable>("30457,14885,0"),
"Malign"
{ "Emperor;common",  "Tracks/emperor.wav",
StylePtr<MainRotoscope>("65535,0,0 ~ 2"),
"Emperor"
{ "Stranger;common",  "Tracks/rebelsmusic4.wav",
StylePtr<MainRotoscope>("65535,0,0 ~ 3"),
"Stranger"
{ "Bandit;common",  "Tracks/saltwind.wav",
StylePtr<TheDuel>("65535,0,0 ~ 2 ~ 290"),
"Bandit"
{ "Ronin;common",  "Tracks/saltwind.wav",
StylePtr<TheDuel>("65535,0,0 ~ 1"),
"Ronin"
{ "Ignition_Redux;common",  "Tracks/templemarch.wav",
StylePtr<TheDuel>("65535,110,0 ~ 3"),
"Ignition_Redux"
{ "Legion;common",  "Tracks/vodean.wav",
"Legion"
{ "Binary_Dark;common",  "Tracks/anakin.wav",
StylePtr<Binary>("~ ~ 6"),
"Binary_Dark"
{ "Binary_Light;common",  "Tracks/dueloffates.wav",
StylePtr<Binary>("~ ~ 7"),
"preset20Binary_Light"
{ "Kyber_Blue;common",  "Tracks/rebelsmusic7.wav",
StylePtr<MainRotoscope>("0,0,65535 ~ 2"),
"Kyber_Blue"
{ "Kyber_Green;common",  "Tracks/rebelsmusic7.wav",
StylePtr<MainRotoscope>("0,65535,0 ~ 3"),
"Kyber_Green"
{ "Kyber_Halcyon;common",  "Tracks/rebelsmusic7.wav",
StylePtr<MainRotoscope>("65535,65535,65535 ~ 2"),
"Kyber_Halcyon"
{ "Kyber_Purple;common",  "Tracks/rebelsmusic7.wav",
StylePtr<MainRotoscope>("12029,0,35913 ~ 5"),
"Kyber_Purple"
{ "Kyber_Red;common",  "Tracks/rebelsmusic7.wav",
"Kyber_Red"
{ "Kyber_Yellow;common",  "Tracks/rebelsmusic7.wav",
StylePtr<MainRotoscope>("65535,65535,0"),
"Kyber_Yellow"
BladeConfig blades[1] = {
#ifdef CONFIG_STYLES
/*--------------------------------- MainRotoscope---------------------------------*/
using MainRotoscope =
OS7.14 v2.242cp
This Style Contains 30 Unique Combinations
Style Options:
1: Rotoscope - Single Color (Prequels)
2: Rotoscope (Subtle)
3: Hyper Responsive Rotoscope (Erratic)
4: Hyper Responsive Rotoscope (Sequels)
Base Color: BaseColorArg (0)
PowerUp Effect Options: Default (0): Power Surge (Stable), 1: Power Burst Forward, 2: Power Flash [Color: IgnitionColorArg]
Retraction Effect Options: Default (0): Standard Retraction, 1: SparkTip Retraction [Color: RetractionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Stab Effect: Sparking Stab [Color: StabColorArg]
Special Ability 1: Toggle Rain Mode Uses trloop00.wav or trloop/000/000.wav (rain sounds looped)
Special Ability 2: Toggle Lightning Mode Uses tr00.wav or or tr/000/000.wav (thunder or lightning strike)
Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,Mix<Sin<Int<16>,Int<32768>,Int<18000>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Stripes<12000,-200,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<20000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,Mix<Scale<IsLessThan<SlowNoise<Int<2000>>,Int<18000>>,Int<0>,Int<32768>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Stripes<12000,-800,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,SparkleF<300,800>>>,ColorSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrFade<100>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Int<0>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<100>>,Int<1000>,Int<4500>>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Int<0>>,TrSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrInstant,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,0>,BrownNoiseFlickerL<RgbArg<BASE_COLOR_ARG,Rgb<0,255,3>>,Int<200>>,TrRandom<TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,2>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,3>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,4>>>>>>>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrFade<1200>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<450>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<450>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<450>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,Black>>;
 add to preset as StylePtr<MainRotoscope>()
/*--------------------------------- MainUnstable---------------------------------*/
using MainUnstable =
/* copyright Fett263 KyloRen (Primary Blade) OS7 Style
Base Style: Kylo Ren Unstable (Supreme Leader)
PowerUp Effect: Power Surge (Unstable V2) [Color: IgnitionColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Blast Effect: Responsive Blast Wave (Sound Based) [Color: BlastColorArg]
Emitter Effect: Unstable Flare with Random Pulse [Color: AltColor2Arg]
Layers<StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,SparkleF<300,800>>>,ColorSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrFade<100>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Int<0>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<100>>,Int<1000>,Int<4500>>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Int<0>>,TrSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrInstant,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,0>,BrownNoiseFlickerL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Int<200>>,TrRandom<TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,2>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,3>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,4>>>>>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<ALT_COLOR2_ARG,Rgb<255,35,0>>,Int<0>>,TrSparkX<RgbArg<ALT_COLOR2_ARG,Rgb<255,35,0>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<ALT_COLOR2_ARG,Rgb<255,35,0>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<6000>>>,Int<-6000>>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,40>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,Black>>
 add to preset as StylePtr<MainUnstable>()
/*--------------------------------- TheDuel---------------------------------*/
using TheDuel =
/* copyright Fett263 Visions (Primary Blade) OS7 Style
This Style Contains 12 Unique Combinations
Style Options:
Default (0): The Duel: Ronin
1: The Duel: Bandit Leader
2: The Village Bride: F
PowerUp Effect Options: Default (0): Power Surge (Unstable V2), 1: Power Surge (Unstable V1) [Color: IgnitionColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,HumpFlicker<Stripes<20000,-800,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,50>,HumpFlicker<Stripes<20000,-1200,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,50>,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,AudioFlicker<Mix<Int<6553>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<10992>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,SparkleF<300,800>>>,ColorSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrFade<100>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Int<0>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<100>>,Int<1000>,Int<4500>>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Int<0>>,TrSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrInstant,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,0>,BrownNoiseFlickerL<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Int<200>>,TrRandom<TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,2>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,3>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,4>>>>>>>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,40>,TrFade<1200>>,TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<1200>>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,Black>>
 add to preset as StylePtr<TheDuel>()
/*--------------------------------- Binary---------------------------------*/
using Binary =
/* copyright Fett263 Greyscale (Primary Blade) OS7 Style
Style Options:
Default (0): Decay (Inverted Rolling Pulse with Ripple Swing)
1: Splinter (Swing Speed - Split Blade)
2: Exalted (Unstable Blade - Ripple Swing)
3: Engine Grip (Unstable Blade - Fire Spark - AudioFlicker Swing)
4: Crispity (Unstable Blade - AudioFlicker Swing)
5: Analog (AudioFlicker with Ripple Swing)
Lockup Effect:
0: mainLockMulti0Shape - Begin: Real Clash - Style: Intensity Vortex - End: Full Blade Absorb
0: mainLBMulti0Shape - Begin: Responsive Impact - Style: Strobing Unstable Flicker - End: Full Blade Absorb
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Blast Effect: Responsive Blast Wave (Large) [Color: BlastColorArg]
Clash Effect: Responsive Clash with Ripple [Color: ClashColorArg]
Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Layers<StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Mix<Int<25746>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Mix<Sin<Int<23>>,Mix<Int<19504>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,RotateColorsX<Int<32000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Mix<Sin<Int<16>>,Mix<Int<3167>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,White>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Mix<Sin<Int<18>>,Mix<Int<11000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Mix<Int<22000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>>,AlphaL<Stripes<1000,2000,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Black>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Black>,SwingSpeed<500>>>,Mix<SmoothStep<Scale<SwingSpeed<400>,Int<6000>,Int<24000>>,Int<10000>>,Stripes<5000,-1300,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,RotateColorsX<Int<800>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Mix<Int<24000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>>,Layers<Mix<SwingSpeed<400>,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,0,6,10,1000,2>,AudioFlicker<RotateColorsX<Int<800>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Mix<Int<21760>,Black,RotateColorsX<Int<400>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>>>,AlphaL<Stripes<2500,-3000,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Pulsing<Mix<Int<3555>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>>,Layers<StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,RandomPerLEDFlicker<Mix<Int<3276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,300>,Mix<Int<10720>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,0,6,10,1000,2>,AlphaL<AudioFlickerL<RotateColorsX<Int<31600>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,SwingSpeed<400>>,AlphaL<Stripes<3000,-1600,Mix<Sin<Int<30>>,RotateColorsX<Int<28900>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,RotateColorsX<Int<30000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Mix<Sin<Int<30>>,Mix<Int<16384>,Black,RotateColorsX<Int<28900>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Mix<Int<10992>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Mix<Sin<Int<26>>,RotateColorsX<Int<30000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,RotateColorsX<Int<29000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Mix<Sin<Int<24>>,Mix<Int<8167>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Mix<Int<11565>,Black,RotateColorsX<Int<28900>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>>>,Bump<Scale<SwingSpeed<400>,Int<1000>,Int<34000>>,Int<12000>>>>,Layers<StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,RandomPerLEDFlicker<Mix<Int<6000>,Black,RotateColorsX<Int<32000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,300>,Mix<Int<10772>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,0,6,10,1000,2>,AlphaL<AudioFlickerL<RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,SwingSpeed<400>>>,Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Mix<Int<20000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,AlphaL<RotateColorsX<Int<27000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,SwingSpeed<500>>,AlphaL<Stripes<2500,-4000,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>,Mix<Int<7710>,Black,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Pulsing<Mix<Int<3855>,Black,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,SparkleF<300,800>>>,ColorSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrFade<100>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Int<0>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<100>>,Int<1000>,Int<4500>>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Int<0>>,TrSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrInstant,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,0>,BrownNoiseFlickerL<RgbArg<BASE_COLOR_ARG,Rgb<247,2,2>>,Int<200>>,TrRandom<TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,2>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,3>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,4>>>>>>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,40>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<200>,Int<100>,Int<400>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1400,-2000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<38000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<2000,3200,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<18000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<8000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1600,2600,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<18000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<8000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,BrownNoiseFlickerL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,Black>>
 add to preset as StylePtr<Binary>()
If you use the code tag when posting configs, it puts it in a scroll box and will prevent super long posts like this one.
I edited the post to add ``` before and after.
Please post the full error message from arduino as well.
Config looks fine, need to see full error message.
I think that might have been the forum eating HTML-like tags, maybe take another look?
Yeah, caught that - edited previous reply.
Arduino: 1.8.19 (Windows 10), Board: "Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Scorc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Scorc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Scorc\OneDrive\Desktop\ProffieOS\config\libraries -fqbn=proffieboard:stm32l4:ProffieboardV2-L433CC:usb=cdc_msc_webusb,dosfs=sdspi,speed=80,opt=os -ide-version=10819 -build-path C:\Users\Scorc\AppData\Local\Temp\arduino_build_825986 -warnings=none -build-cache C:\Users\Scorc\AppData\Local\Temp\arduino_cache_129381 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Scorc\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -prefs=runtime.tools.arm-none-eabi-gcc-9-2020-q2-update.path=C:\Users\Scorc\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -verbose C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\ProffieOS.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Scorc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Scorc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Scorc\OneDrive\Desktop\ProffieOS\config\libraries -fqbn=proffieboard:stm32l4:ProffieboardV2-L433CC:usb=cdc_msc_webusb,dosfs=sdspi,speed=80,opt=os -ide-version=10819 -build-path C:\Users\Scorc\AppData\Local\Temp\arduino_build_825986 -warnings=none -build-cache C:\Users\Scorc\AppData\Local\Temp\arduino_cache_129381 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Scorc\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -prefs=runtime.tools.arm-none-eabi-gcc-9-2020-q2-update.path=C:\Users\Scorc\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -verbose C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\ProffieOS.ino
Using board 'ProffieboardV2-L433CC' from platform in folder: C:\Users\Scorc\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0
Using core 'stm32l4' from platform in folder: C:\Users\Scorc\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0
Detecting libraries used...
"C:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -DARDUINO=10819 -DARDUINO_STM32L4_BUTTERLY -DARDUINO_ARCH_STM32L4 -DSTM32L433xx -DPROFFIEBOARD_VERSION=2 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=1 -DDOSFS_SFLASH=0 "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\cores\\stm32l4" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\variants\\STM32L433CC-ProffieboardV2" "C:\\Users\\Scorc\\AppData\\Local\\Temp\\arduino_build_825986\\sketch\\ProffieOS.ino.cpp" -o nul
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -DARDUINO=10819 -DARDUINO_STM32L4_BUTTERLY -DARDUINO_ARCH_STM32L4 -DSTM32L433xx -DPROFFIEBOARD_VERSION=2 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=1 -DDOSFS_SFLASH=0 "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\cores\\stm32l4" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\variants\\STM32L433CC-ProffieboardV2" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\libraries\\Wire\\src" "C:\\Users\\Scorc\\AppData\\Local\\Temp\\arduino_build_825986\\sketch\\ProffieOS.ino.cpp" -o nul
"C:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -DARDUINO=10819 -DARDUINO_STM32L4_BUTTERLY -DARDUINO_ARCH_STM32L4 -DSTM32L433xx -DPROFFIEBOARD_VERSION=2 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=1 -DDOSFS_SFLASH=0 "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\cores\\stm32l4" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\variants\\STM32L433CC-ProffieboardV2" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\libraries\\Wire\\src" "C:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\libraries\\Wire\\src\\Wire.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -DARDUINO=10819 -DARDUINO_STM32L4_BUTTERLY -DARDUINO_ARCH_STM32L4 -DSTM32L433xx -DPROFFIEBOARD_VERSION=2 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=1 -DDOSFS_SFLASH=0 "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\cores\\stm32l4" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\variants\\STM32L433CC-ProffieboardV2" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\libraries\\Wire\\src" "C:\\Users\\Scorc\\AppData\\Local\\Temp\\arduino_build_825986\\sketch\\ProffieOS.ino.cpp" -o "C:\\Users\\Scorc\\AppData\\Local\\Temp\\arduino_build_825986\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Scorc\\AppData\\Local\\Temp\\arduino_build_825986\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -DARDUINO=10819 -DARDUINO_STM32L4_BUTTERLY -DARDUINO_ARCH_STM32L4 -DSTM32L433xx -DPROFFIEBOARD_VERSION=2 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=1 -DDOSFS_SFLASH=0 "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0/system/STM32L4xx/Include" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\cores\\stm32l4" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\variants\\STM32L433CC-ProffieboardV2" "-IC:\\Users\\Scorc\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\3.6.0\\libraries\\Wire\\src" "C:\\Users\\Scorc\\AppData\\Local\\Temp\\arduino_build_825986\\sketch\\ProffieOS.ino.cpp" -o "C:\\Users\\Scorc\\AppData\\Local\\Temp\\arduino_build_825986\\sketch\\ProffieOS.ino.cpp.o"
In file included from C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\ProffieOS.ino:1564:
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:35:22: error: expected constructor, destructor, or type conversion before '(' token
   35 |   SaberBase::DoEffect(EFFECT_FONT_DIRECTORY_NOT_FOUND, 0);
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:41:3: error: 'beeper' does not name a type
   41 |   beeper.Beep(0.5, 261.63 * 2); // C4
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:42:3: error: 'beeper' does not name a type
   42 |   beeper.Beep(0.5/3, 246.94 * 2); // B3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:43:3: error: 'beeper' does not name a type
   43 |   beeper.Beep(0.5/3, 220.00 * 2); // A3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:44:3: error: 'beeper' does not name a type
   44 |   beeper.Beep(0.5/3, 196.00 * 2); // G3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:45:3: error: 'beeper' does not name a type
   45 |   beeper.Beep(0.5, 174.61 * 2); // F3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:46:3: error: 'beeper' does not name a type
   46 |   beeper.Beep(0.5, 146.83 * 2); // D3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:47:3: error: 'beeper' does not name a type
   47 |   beeper.Beep(0.5, 130.81 * 2); // C3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:50:1: error: expected declaration before '}' token
   50 | }
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:73:22: error: expected constructor, destructor, or type conversion before '(' token
   73 |   SaberBase::DoEffect(EFFECT_ERROR_IN_FONT_DIRECTORY, 0);
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:79:3: error: 'beeper' does not name a type
   79 |   beeper.Beep(0.25, 174.61 * 2); // F3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:80:3: error: 'beeper' does not name a type
   80 |   beeper.Beep(0.25, 196.0 * 2); // G3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:81:3: error: 'beeper' does not name a type
   81 |   beeper.Beep(0.25, 174.61 * 2); // F3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:82:3: error: 'beeper' does not name a type
   82 |   beeper.Beep(0.25, 164.81 * 2); // E3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:83:3: error: 'beeper' does not name a type
   83 |   beeper.Beep(0.5, 146.83 * 2); // D3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:84:3: error: 'beeper' does not name a type
   84 |   beeper.Beep(0.5, 164.81 * 2); // E3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:85:3: error: 'beeper' does not name a type
   85 |   beeper.Beep(0.5, 196.0 * 2); // G3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:86:3: error: 'beeper' does not name a type
   86 |   beeper.Beep(0.5, 246.94 * 2); // B3
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:87:3: error: 'beeper' does not name a type
   87 |   beeper.Beep(0.5, 261.63 * 2); // C4
C:\Users\Scorc\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\common\errors.h:90:1: error: expected declaration before '}' token
   90 | }
Using library Wire at version 1.0 in folder: C:\Users\Scorc\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0\libraries\Wire
i’m sorry i didn’t know how to do what it was asking when it said to compress the text.
is it three ``` before and after?
Yes, edited…
Those compile errors are unusual.
I’m going to have to try your config file and see if I get the same problems or not.
If not, then there must be changes (intentional or unintentional) elsewhere in ProffieOS causing these errors…
that makes me feel a little better, like i said ive done three configs for this saber before. i WILL add that when i posted the config i deleted the fett263 and greyscale links that were in it from the config builder. would those be an issue in arduino themselves? (also i’ll be back tomorrow, i gotta head out for work now)
It compiles fine on 7.14.
I would download a fresh copy of the OS, move your config file over, and try again.
I’ll do that tonight when i get home, thank you.
So that worked and i no longer have errors, it says upload successful but it also says cannot open dfu device 10x and is still trying to load my old board config to the saber. Every font’s boot is “font directory not found”
You need to edit the CONFIG_FILE line in the new ProffieOS.ino file (which you open in Arduino) to be the name of your config file.
Read the big box of text too
  |  You can have multiple configuration files, and specify which one |
  |  to use here by removing the two slashes at the beginning.        |
  |  **NOTE** Only ONE line should be left uncommented at a time!     |
  |  Add the slashes to any that you are not using.                   |
I have that done, my old config was named lukeconfig and now its “skywalkerconfigv2”
I feel like there’s a basic step i missed somewhere. Im flashing it to the board but its acting completely unchanged.
It doesn’t sound like you successfully uploaded, see here:
So it looks like its the dfu driver issue, cause i have it set to “port com3 proffieboard” and it is reading as stm32 bootloader
And i do get the upload successful.
It does also say that arduino is using/used a “precompiled core” in the upload.
So now i just need to run the proffie dfu setup right?
