I lost my volume button controls
Hi y’all,
So I just uploaded a config file for my proffie v2 I found online; (it did not come from my seller), and now I’ve lost the ability to raise and lower the volume. I used to be able to do this with the saber powered off and holding down the aux button until I heard the beep and then I could press the buttons to adjust the volume. Now, after the config upload, holding down the button while powered off toggles the ability to twist the saber so it goes to the next or previous sound/blade profile which is weird and unnecessary since the aux button does this when pressed anyway. I’ve requested the original config from my seller but they have been less than helpful thus far and who know what they’ll come back with if anything. So, does anyone here have any ideas or suggestions I can try to reimplement this feature? Any advice would be greatly appreciated. I’m brand new to this group by the way. Much thanks in advance!
Which prop is in your config, different props have different controls. Refer to the controls for the prop you defined in your config.
Hi! Thanks for responding so quickly. Here is what is currently listed in my config:
Do you know which prop has the button scheme I’m looking for? I suppose I could try them all but that might take a while =).
Refer to this page, be sure you did the required Set Up for Voice Prompts and refer to controls.
I think I can figure it out by reading the features of each prop. I’ll let you know how it goes!
I linked the page above :wink:
Awesome, that was a great help, thank you!
