getting this error or errors in arduino and i have no clue what im looking at to fix it
In file included from E:\extra\ProffieOS\ProffieOS.ino:571:
E:\extra\ProffieOS\config\s3config.h:719:2: error: expected '}' before '{' token
719 | { "Ice_Saber;common", "tracks/track_19.wav",
E:\extra\ProffieOS\config\s3config.h:35:19: note: to match this '{'
35 | Preset blade[] = {
E:\extra\ProffieOS\config\s3config.h:719:2: error: expected ',' or ';' before '{' token
E:\extra\ProffieOS\config\s3config.h:737:495: error: expected unqualified-id before ',' token
737 | TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,DeepSkyBlue>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Int<4000>,RotateColorsX<Variation,DeepSkyBlue>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()},
E:\extra\ProffieOS\config\s3config.h:742:4: error: expected unqualified-id before '}' token
742 | };
E:\extra\ProffieOS\config\s3config.h:742:4: error: expected declaration before '}' token
Compilation error: expected '}' before '{' token
So i made it past the arduino stuff but i had to download zadig that worked fine but the sound fonts still didnt work so i was gonna try again but now my pc doesnt recognize the lightsaber anymore
oh and here the config file btw file:///D:/ProffieOS-v6.8/ProffieOS/config/s3config.h
should i just leave this alone or should i put it in the proffieos config folder
The SD card contents will only show on the computer if the board is set up to act as a card reader, otherwise you’d just remove the card from the board and use a standalone USB card reader.
Arduino menu Tools>USB Type> would need to be set to either Serial + Mass Storage, or Serial + Mass Storage + WebUSB, and upload.
Then the SD card will mount to the PC on reboot.
Be sure to Eject the SD card properly from the PC before disconnecting the USB cable or uploading so as to avoid card corruption.
According to the path you posted , it already is in the ProffieOS/config folder, although the D: drive is typically not your main C: drive, so if that’s a path to the file on the SD card, then yes, you need to copy it to the working ProffieOS directory you have on the Computer itself…wherever you have that.
when i try to do anything in arduino now all i get is this error
In file included from D:\ProffieOS-v6.8\ProffieOS\ProffieOS.ino:567:
D:\ProffieOS-v6.8\ProffieOS\config\s3config.h:30:9: fatal error: …/props/saber_sabertrio_buttons.h: No such file or directory
30 | #include"…/props/saber_sabertrio_buttons.h"
compilation terminated.
Compilation error: …/props/saber_sabertrio_buttons.h: No such file or directory
The board dual boots.
If it’s booted normally into ProffieOS, it shows up on a COM port in Arduino.
If it’s booted into bootloader, it will NOT show up on a COM port, and would be visible in Devices and Printers as STM32 BOOTLOADER device.
The only time you need to worry about bootloader is the first time you connect the board to the PC and need to install the drivers for STM32 BOOTLOADER using Zadig.
If you use this instead, you don’t even need to deal with that:
As long as D: is not your SD card, that’s totally fine.
okay i think im starting to understand maybe
but if i wanna download new soundfonts and blade styles i use a sd card reader and i dont have to worry about Arduino outside of the 1st time you set it up
i just have to drag and drop stuff into proffieOS and that should be fine?
Because you have an incorrect double-dot indicating a parent directory.
If you use a text editor that is not based on Plain Text, you can get funky Unicode character issues such as this.
Your .. has been replaced with ellipses ...
and I wouldn’t be surprised if your quotation marks are all slanty versions “ ” instead of plain text straight ones " "
Download and use Sublime Text instead of Notepad or whatever you’re using to edit your config Sublime Text
or Visual Studio Code Visual Studio Code
Sound fonts live on the SD card.
Programming the board with Blade styles is done through Arduino, you will use that often.
STM32 BOOTLOADER driver installation to the computer is what is a one-time thing.
okay downloaded sublime text now what lol i know they said you would need to know a bit to use a proffie board but i got off work at 330 and now it 9 and i havent gotten a single sound font to work . things actually seem worse then when i started
