I have most of the controls but i cannot change the volume on my proffie. I also dont know how to turn off twisting for fonts
If you’re using my prop, I recommend reviewing the Set Up Instructions and the controls. My guess is you didn’t properly set up the Voice Prompts correctly.
After you set up the Voice Prompts (they are required for my prop) just review the controls for each feature.
See here:
It worked thanfully and now im trying to add the circular volume menu but i cannot seem to understand where to put the EFFECT_VOLUME_LEVEL in my preset
These are two very different things.
This is just a visual representation of the volume level. Just use the library, it will build the style for you, just add the option on Enhancements screen.
#define FETT263_CIRCULAR_VOLUME_MENU
This define goes with the other defines at top of your config.
