I can not get my blade to light past 132 pixels
I have a 144 pixel blade on my saber and can not get it to light up past 132 pixels. Using Fett’s configurator I have tried configuring the max pixels to exactly 144, 150, and 160; none resolved my issue. I then went into editing mode to adjust the blade length manually and I will get the white light at pixel 132 but once i increase it to 133 no extra pixels light up and the white light stops like its trying to move to the next pixel. I am honesty stuck and have no clue what to do next.
MaxLedsPerStrip should always be 144 unless you have a blade longer than 144.
Your blade max length is controlled in the BladeConfig at the bottom of your config.h
Please post your config file and we’ll take a look.
myconfig.h (13.8 KB)
This config should handle blades up to 144, so…
Is this the problem?
I do not notice any error like that but here is my Arduino log
Opening DFU capable USB device…
ID 0483:df11
Claiming USB DFU Interface…
Setting Alternate Setting #0
dfuERROR, clearing status
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 199616
Download [=========================] 100% 199616 bytes
Download done.
File downloaded successfully
And you’re sure the config above is the one you’re uploading?
Let’s introduce an error.
In your first style remove the “S” in “StylePtr”.
StylePtr<...
Becomes
tylePtr<...
Save and try to upload.
If you get an error put the “S” back and upload and test Edit Blade Length again.
If you don’t get an error you’re uploading a different config than you think you are so check the CONFIG_FILE define in ProffieOS.ino and find which file you’re actually uploading (you can confirm with same steps as above).
Then either change the define or update the config you defined.
Ya that’s the same config file that’s on my board. But I changed the StylePtr and it did give me an error
Arduino: 1.8.19 (Windows 10), Board: “Proffieboard V3, Serial + Mass Storage + WebUSB, SDCARD (SDIO High Speed), 80 MHz, Smallest Code”
In file included from C:\Users\camer\OneDrive\Desktop\ProffieOS\ProffieOS-v7.12\ProffieOS\ProffieOS.ino:634:
C:\Users\camer\OneDrive\Desktop\ProffieOS\ProffieOS-v7.12\ProffieOS\config\myconfig.h:71:1: error: ‘tylePtr’ was not declared in this scope; did you mean ‘StylePtr’?
71 | tylePtr<Mix<SmoothStep<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<36000>,Scale<BladeAngle<>,Int<10924>,Int<54000>>>,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<-1>,Scale<BladeAngle<>,Int<-10000>,Int<-1>>>>,Black,Remap<Scale<RampF,Int<0>,Scale<IsLessThan<BladeAngle<>,Int<15000>>,Int<32768>,Scale<BladeAngle<0,15000>,Int<60000>,Int<32768>>>>,Layers<Mix<BladeAngle<>,StaticFire<Gradient<RotateColorsX<Int<1600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<1000>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<400>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,2,0,1800,10>,StaticFire<Gradient<RotateColorsX<Int<1600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<1200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,4,0,2200,2>>,AlphaL<TransitionEffect<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrInstant,TrConcat<TrFade<1000>,Red,TrFade<1000>,Orange,TrFade<1000>>,EFFECT_IGNITION>,SmoothStep<IntArg<EMITTER_SIZE_ARG,1620>,Int<-6000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30545>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Scale<ClashImpactF<>,Int<100>,Int<600>>>,TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,StripesX<Int<16000>,Scale<ClashImpactF<>,Int<3000>,Int<10000>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,20,128>,Rgb<128,0,0>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,DodgerBlue,Red>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,10,80>,Rgb<90,0,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<50000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,EFFECT_CLASH>,LockupTrL<AlphaL<StripesX<Int<16000>,Int<12000>,Rgb<128,0,0>,Red,Rgb<90,0,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<50000>>>,TrConcat<TrJoin<TrDelayX<Scale<ClashImpactF<>,Int<2000>,Int<100>>>,TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,AlphaL<StripesX<Int<16000>,Scale<ClashImpactF<>,Int<3000>,Int<10000>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,20,128>,Rgb<128,0,0>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,DodgerBlue,Red>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,10,80>,Rgb<90,0,0>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<50000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<600>,Int<100>>>>,TrFade<400>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<Stripes<2000,3000,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Mix<Sin<Int<30>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<8192>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30658>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30545>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30545>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrFadeX<BendTimePowInvX<IgnitionTime<150>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Red,TrFadeX<BendTimePowInvX<IgnitionTime<150>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,DarkOrange,TrFadeX<BendTimePowInvX<IgnitionTime<150>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,White,TrFadeX<BendTimePowInvX<IgnitionTime<150>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>>,TrWipeX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,1492>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,1492>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,1492>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>>>>>(“~ ~ ~ ~ 150”),
  | StylePtr
C:\Users\camer\OneDrive\Desktop\ProffieOS\ProffieOS-v7.12\ProffieOS\config\myconfig.h:71: error: expected primary-expression before ‘>’ token
Ok, then do this ^
Just tried it and the blade length is still not going past 132. I did try to click verify before I tried to upload onto the board and got some return code that I don’t understand and don’t know If it would be helpful.
c:/users/camer/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\camer\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region `SRAM2’ not declared
c:/users/camer/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 16 bytes
Sketch uses 199608 bytes (39%) of program storage space. Maximum is 507904 bytes.
dfu-util 0.9
Those are just warnings, they can be ignored.
In Edit Blade Length, what is actually happening when you try to go past 132 pixels?
It’s starting to sound more and more like this blade is actually broken.
I don’t suppose you have another blade you can test with?
unfortunately this is the only 144 blade that I have. It is a DIY blade that I got off the Saber Armory and so is the saber that I am using so now that I am thinking about it I will have to double check my wiring and test the blade on another saber.
If it stops at pixel 132, then the problem is not the wiring. It’s would either be a dead pixel, or a cracked solder joint.
kk, will try after I get off work and will update after
I reached out to The Saber Armory and it turns out that their 88cm blades are not 144 but 132 which would explain why the light would not go past 132. The other thing that I had failed to realize is the plastic for the blades come in one meter segments, so they have to be cut to size. I simply cut it to size and the blade is working how it should now.
