When I upload my config file ardiuno says that i used 95% of the space
but I only have 18 Saberfonts on there
is there any way to shorten that number? I want to add some more
maybe there is the possibility to put two fonts together? I have 3 fonts that are nearly identical except the colors
“space” is not very well defined, as there are 3 different types of “space” on a proffieboard:
- sd card space
- flash memory space
- RAM space
In your case you’re talking about flash memory space.
I wrote a wiki page about how to save flash memory space, so let’s start there:
Please note that fonts take little or no flash memory. Blade styles use up flash memory, not fonts.
That’s what I am looking for thx
does the //Text affect memory ?
// indicates a comment follows.
Comments take no additional memory as they are are ignored by the compiler.
Same goes for line returns and spaces.
