OK, I admit I’m getting picky now, but I’ll ask the question on the off chance the answer is simple…
I’ve noticed on some hilts that the button action is mechanically strong enough, or the ignition effect is sufficiently resonant or bassy, to initiate a clash while the blade is still igniting.
Obviously volume or chassis securing can help, but my question is, how easy is it to add a line, presumably to the prop, to tell the board not to run any effect until the ignition effect has completed? Or maybe do it as a time thing, so tell it no effect, other than the ignition effect, for, say, 1.2 seconds after button actuation.
As I say it’s not a biggie, but I’d be curious to know how easily do-able this is.
Thanks as always.
You can also hook up to Serial Monitor to see “when” clash triggers. It might give a clue. Most likely cause is speaker vibrations from out.wav. If adjusting CLASH_THRESHOLD_G and VOLUME don’t work, look to above thread.
