Hello!
I am having trouble trying to make a secondary blade style that matches my primary. For reference, im using the crispity font from greyscale and this is the style,
StylePtr<Layers<
StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<11805,0,1587>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,
//Unstable red/pink
TransitionEffectL<TrConcat<TrFade<200>,AlphaL<RotateColorsX<Variation,DeepPink>,SwingSpeed<400>>,TrDelay<30000>,AlphaL<RotateColorsX<Variation,DeepPink>,SwingSpeed<400>>,TrFade<800>>,EFFECT_FORCE>,
//Force effect, temporarily allows color change based on swing speed
AlphaL<AudioFlickerL<RotateColorsX<Variation,DeepPink>>,SwingSpeed<400>>,
//Swing effect, audioflicker, Deep Pink connects the tip and emitter when swinging
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
//Responsive lightning block
AlphaL<RotateColorsX<Variation,DeepPink>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Sparking emitter flare
ResponsiveStabL<Orange>,
//Responsive stab
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<255,150,150>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>>,TrFade<1200>>,EFFECT_IGNITION>,
//Unstable ignition effect
AlphaL<RotateColorsX<Variation,DeepPink>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<28000>,Int<33000>>,Int<10000>>>,
//Sparking tip flare
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTip<White,100>,TrColorCycle<1065>>,
//Spark tip ignition, cycle down retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Sin<Scale<Trigger<EFFECT_RETRACTION,Int<3000>,Int<1000>,Int<500>>,Int<70>,Int<550>>>,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb16<65535,0,2716>>>,Bump<Scale<Trigger<EFFECT_PREON,Int<3000>,Int<1000>,Int<500>>,Int<41000>,Int<32768>>>>,TrDelay<3000>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<520>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<520>,Int<550>,Int<520>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<420>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<420>,Int<450>,Int<420>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<340>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<340>,Int<430>,Int<340>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<300>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<300>,Int<400>,Int<300>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<240>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<240>,Int<380>,Int<240>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<210>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<210>,Int<360>,Int<210>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<190>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<190>,Int<340>,Int<190>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<170>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<170>,Int<320>,Int<170>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<160>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<160>,Int<300>,Int<160>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<150>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<150>,Int<250>,Int<150>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<130>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<130>,Int<150>,Int<130>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<100>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<100>,Int<100>,Int<100>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<70>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<70>,Int<500>,Int<70>,Int<0>>>,Black,TrInstant>,EFFECT_PREON>
//Preon effect, HUGE thanks to /u/NoSloppy for this!
How do i make the same code but for a secondary blade style, Or how can i paste this code into fetts blade editor?
*note: ive tried the actual greyscale font blade maker on fetts website, but the font i make even with the instructions never looks how it should, online or on the blade. i cant seem to find a place to copy this code either.
Thank you!
