Using the new MENU_SPEC_TEMPLATE FETT263_MENU_SPEC on 2 button is pretty straight forward but I can’t seem to figure out how to exit menus on a 1 button setup.
@Fett263 how do you exit menus on a 1 button setup?
That’s a good question, I don’t actually know. I added the support for the new menu system but I don’t see 1 button listed in the documentation and I don’t use 1 button on any of my sabers.
@profezzorn are you able to help?
This is from the select_cancel_mode.h file
bool mode_Event2(enum BUTTON button, EVENT event, uint32_t modifiers) override {
switch (EVENTID(button, event, 0)) {
case EVENTID(BUTTON_POWER, EVENT_FIRST_SAVED_CLICK_SHORT, 0):
select();
return true;
case EVENTID(BUTTON_POWER, EVENT_SECOND_SAVED_CLICK_SHORT, 0):
case EVENTID(BUTTON_AUX, EVENT_FIRST_SAVED_CLICK_SHORT, 0):
exit();
return true;
return false;
When you’re in a mode (the menu system) these default controls override anything the prop file does, unless the prop has it’s own template<class SPEC> with a mode that uses a mode_Event2 override.
So the answer here is: double click power to exit.
I’ll try it out when I get home from work.
Thank you!
