How to check my saber is BLADE_DETECT capable
So I have a saber and wanted to see if I could enable the BLADE_DETECT and I’m hoping to use it. what do I need to check to see if it works?
You need a wire from some pad on the board to the BD pin on the pogo pin board.
You also need to know the pin number of the pad the wire is attached to.
