How to add the motion sensor control with V3 ?
OS 7.8
Thank you very much !
Gestures are setup in prop files.
Read the instructions in the top comment section of the prop file you are using.
(The one you set with the
#include "../props/PROPFILENAME"
line in your config file.)
The prop files are found in the ProffieOS/props folder.
Open with any text editor to read.
