Help with Squee of Death
So I did some testing and edited my config file with some different values to try for example less sensitive swing on etc. I also left everything on OS v7.15 because it is working well with the Prop File reading from the config.
But I stumbled upon a new problem and I am running out of time for the upcoming convention.
I started to have problems to initiate LockUp (Hold PWR Button and Clash), with problems I mean, i could not initiate at all, but when I do now, the sabre lags and freezes while playing a loud “beeping” sound. Have to dissasemble then quickly and killswitch the core.
//PROFFIECONFIG OS_VERSION 7.15
#define SHARED_POWER_PINS
#define NUM_BUTTONS 1
#define BLADE_DETECT_PIN blade4Pin
#define VOLUME 2100
#define BOOT_VOLUME 1400
#define CLASH_THRESHOLD_G 3.5
#define PLI_OFF_TIME 10000
#define IDLE_OFF_TIME 300 * 1000
#define MOTION_TIMEOUT 300 * 1000
#define SAVE_PRESET
#define FILTER_CUTOFF_FREQUENCY 40
#define FILTER_ORDER 8
#define EXTRA_COLOR_BUFFER_SPACE  60
#define FETT263_SWING_ON_SPEED 550
#define FETT263_BM_DISABLE_OFF_BUTTON
#define FETT263_TRACK_PLAYER_NO_PROMPTS
#define FETT263_BM_CLASH_DETECT 6.000000
#define FETT263_SWING_ON_PREON
Is there anything ProffieConfig adds to the config which causes the LockUp to not work properly? If not, is it possible to “disable” LockUp temporarily, so that I don’t accidentally freeze up the Saber.
Oh and to add some more information I got the Saber to freeze up while doing a simple Clash. I start to think that the SD Card is not capable with the settings from ProffieConfig. Since it worked with the original configtop just fine, here it is for comparison:
#define VOLUME 1750
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define SAVE_STATE
#define SAVE_VOLUME
#define SAVE_PRESET
#define SAVE_COLOR_CHANGE
#define FETT263_FORCE_PUSH
#define FETT263_MULTI_PHASE
#define FETT263_SAVE_CHOREOGRAPHY
#define FETT263_MAX_CLASH16
#define FETT263_BM_CLASH_DETECT 3
#define COLORWHEEL_ZOOM
#define FETT263_BATTLE_MODE
#define FETT263_STAB_ON_NO_BM
#define FETT263_THRUST_ON
I’ll try to replicate some of the original settings in ProffieConfig, to match it and maybe find the reason for the freeze, could be the Audio Cutoff or anything related to audio.
It seems likely to be a slow SD card. Have you tried running sdtest?
A new software version with complex bladestyles and a slow SD card could cause issues you haven’t seen before. The crashing is odd though, but it’s possible ProffieOS has a bug.
In any case, this probably should be moved to its own thread, this wouldn’t be because of ProffieConfig.
^ That. The noise you’re hearing is affectionately called “the squee of death” because the SD isn’t keeping up. Pull a copy of your font folders and then delete all contents, reformat with SD Memory Card Formatter for Windows/Mac - SD Association taking note of the readout once the reformat is complete to see if you’ve lost x-amount of space, and put the font packs back in. Then if ya really wanna get technical reenable diagnostic commands and run the speed test.
Thanks guys, will do everything once I find the time for it. And will surely check the SD Card, since it was supposed to be a good one, whatever that means :slight_smile:
Good one or not, it doesn’t mean it can’t get corrupted.
Moved this thread of discussion to a new thread to keep things tidy.
