Here is the config file:
#define NUM_BLADES 2
#define VOLUME 1200
const unsigned int maxLedsPerStrip = 128;
#define CLASH_THRESHOLD_G 4.5
#define ENABLE_SERIAL
#define FETT263_MULTI_PHASE
#define FETT263_TWIST_ON
#define FETT263_STAB_ON_NO_BM
#define FETT263_SWING_OFF
#define FETT263_THRUST_ON
#define FETT263_THRUST_OFF
// #define ENABLE_SSD1306
// // Max 20 characters
// #define BLE_PASSWORD "your password"
// // Max 32 characters.
// #define BLE_NAME "Your Saber Name"
// // Max 9 characters
// #define BLE_SHORTNAME "Saber"
#define MOTION_TIMEOUT 60 * 3 * 800
{ "Graflex;common", "tracks/venus.wav",
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "chunblue"},
{ "QGJ;common", "tracks/venus.wav",
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), "chungreen"},
{ "SmthGrey;common", "tracks/mercury.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<GhostWhite,Black>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<GhostWhite,Black>,White>,300,800>>(),"white1"},
{ "AhsokaTM;common", "tracks/mars.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<BrownNoiseFlicker<Snow,Blue,50>>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<BrownNoiseFlicker<Snow,Blue,50>>,White>,300,800>>(), "snowblue"},
{ "luke;common", "tracks/venus.wav",
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Cyan,White>,AudioFlicker<Blue,White>>,White>,400,800>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Cyan,White>,AudioFlicker<Blue,White>>,White>,400,800>>(), "Cyan"},
{ "Vader;common", "tracks/mars.wav",
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "chunRed"},
{ "SmthFuzz;common", "tracks/uranus.wav",
StyleFirePtr<Red,Yellow>(),
StyleFirePtr<Red,Yellow>(), "fire"},
{ "Windu;common", "tracks/uranus.wav",
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Magenta,White>,AudioFlicker<Blue,White>>,White>,300,800>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Magenta,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "chunzise"},
{ "DV3;common", "tracks/mars.wav",
StyleFirePtr<RandomBlink<3,Red,Red>,Yellow,1,0,10>(),
StyleFirePtr<RandomBlink<3,Red,Red>,Yellow,1,0,10>(), "KYLO"},
{ "luke5;common", "tracks/venus.wav",
StylePtr<InOutHelper<RandomPerLEDFlicker<Pulsing<Blue,InOutHelper<White,300,800>,800>,Blue>,300,800>>(),
StylePtr<InOutHelper<RandomPerLEDFlicker<Pulsing<Blue,InOutHelper<White,300,800>,800>,Blue>,300,800>>(), "BLUEFLASH"},
{ "TthCrstl;common", "tracks/venus.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<Sparkle<HotPink,Yellow>>,GreenYellow>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<Sparkle<HotPink,Yellow>>,GreenYellow>,300,800>>(), "PINK"},
{ "Fire;common", "tracks/mars.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Cylon<Red,5,20,Red,30,20,1>,GhostWhite,Cylon<Red,5,20,Red,5,20,1>>>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Cylon<Red,5,20,Red,30,20,1>,GhostWhite,Cylon<Red,5,20,Red,5,20,1>>>,White>,300,800>>(), "Cylonwhite"},
{ "TeensySF;common", "tracks/mars.wav",
StylePtr<InOutHelper<EasyBlade<Stripes<1000,1000,Cyan,Magenta,Yellow,Blue>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<Stripes<1000,1000,Cyan,Magenta,Yellow,Blue>,White>,300,800>>(), "rainbow"},
{ "SmthJedi;common", "tracks/venus.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(), "greenflash"},
{ "RgueCmdr;common", "tracks/venus.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<TransitionLoop<Red,TrConcat<TrFade<1000>,GreenYellow,TrFade<200>>>>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<TransitionLoop<Red,TrConcat<TrFade<1000>,GreenYellow,TrFade<200>>>>,White>,300,800>>(), "CC"},
{ "TeenysSF;common", "tracks/mars.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<HumpFlicker<Green,Magenta,50>>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<HumpFlicker<Green,Magenta,50>>,White>,300,800>>(), "EE"},
{ "luke4;common", "tracks/mars.wav",
StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Blue,AudioFlicker<White,Blue>,Red,RandomFlicker<Yellow,Blue>>>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Blue,AudioFlicker<White,Blue>,Red,RandomFlicker<Yellow,Blue>>>,White>,300,800>>(), "KK"},
{ "Rey;common", "tracks/mars.wav",
StylePtr<InOutHelper<EasyBlade<Sparkle<OrangeRed>,White>,300,800>>(),
StylePtr<InOutHelper<EasyBlade<Sparkle<OrangeRed>,White>,300,800>>(), "sparkstar"},
{ "Vortex;common", "tracks/uranus.wav",
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<255,0,0>>,Black,20>,RotateColorsX<Variation,Rgb<4,0,8>>,
BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,15,220>>,70>,RotateColorsX<Variation,Rgb<42,0,105>>>,RotateColorsX<Variation,Rgb<30,0,66>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,
FireConfig<2,3000,0>,FireConfig<2,3000,0>>,AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,
Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,
Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrJoinR<TrWipe<100>,TrWipeIn<100>>>,
SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,
HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,SparkleL<White,100,400>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,
ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,
EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,
SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<32768>>,
Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<350>,Int<300>,Int<350>,Int<32768>>,Mix<SmoothStep<Int<11000>,Int<-2000>>,
Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<300>,Int<300>,Int<300>,Int<32768>>,Mix<SmoothStep<Int<16500>,Int<-2000>>,
Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<250>,Int<300>,Int<250>,Int<32768>>,Mix<SmoothStep<Int<22000>,Int<-2000>>,
Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<200>,Int<300>,Int<200>,Int<32768>>,Mix<SmoothStep<Int<27500>,Int<-2000>>,
Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWipeIn<200>,Mix<SmoothStep<Int<33000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrFade<300>>,
TrConcat<TrWipe<200>,Mix<SmoothStep<Int<27500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<200>,Int<300>,Int<200>,Int<0>>,
Mix<SmoothStep<Int<22000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<250>,Int<300>,Int<250>,Int<0>>,
Mix<SmoothStep<Int<16500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<300>,Int<300>,Int<300>,Int<0>>,
Mix<SmoothStep<Int<11000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<350>,Int<300>,Int<350>,Int<0>>,
Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,
TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrInstant>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,
AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrFade<2000>,
AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,
AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),"tsb"},
{ 0, WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<30, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >()
, CONFIGARRAY(presets) },
Here is the contents of the stock sdcard
here is the fonts I would like to instead:
