How do quotes groups work with special abilities and how should my folders and files be structured and named?
Quote Groups use sub-sub sound set up.
You set up a “quote” folder in your font.
Then set up sub folders like so (these are the groups):
01
02
03
etc.
Then the sound files in each sub folder are named:
000.wav
001.wav
002.wav
When you play Group 1, a sound is randomly played from quote/01/, Group 2 would play from quote/02/, etc.
Just be sure everything is sequential, you can’t skip numbers and you need the same number of files in each group.
Full info here:
