sjw2511
1
Wired up the OLED display, added
#define ENABLE_SSD1306
To my config
but nothing on the display,
Im lead to understand that this include is all it needs to at least display something?
Triple checked all wiring, got VCC > SD Power Pad, GND > GND, SCL > SCL and SDA > SDA
Got voltage coming out of SD Power
Any ideas?
sjw2511
2
Theres continuity between both scl and sda pins and data2 but only when board is powered, is that right?
You should not check continuity with when anything is powered.
If you see no continuity when the board is off, that is most likely not the problem.
You should indeed see something on the screen.
Do you see any errors in the serial monitor?
What kind of display is it?
Where did you get it?
sjw2511
4
Kr sabers
This one KR 128x32 OLED Display Module - Blue or White – The Saber Armory
Ive got 3.3v on scl and sda to gnd at the oled end when powered on
Is it a config thing? Ive read you might need something in the font files? But would that stop it displaying anything at all?
It should still display the logo and the battery meter.
sjw2511
6
Do you have a really basic example config that I can use that would normally get a display?
I can add the blades etc
sjw2511
7
Oh just to add i havent wired my buttons in yet so board is just on and idle not sure if that makes a a diff
Crystal chamber etc lights
There also is no blade hilt connector wired in yet
You can use the configuration generator (scroll down on this page):
https://fredrik.hubbe.net/lightsaber/v5/
sjw2511
9
OLED ribbon to screen snapped off
so delicate
