I’m having trouble getting these effects to work on my saber. I have them all set to the responsive type in the bladestyles, but none of them seem to work and I don’t know why. Are there some settings that need to be changed to have these options work or something? I’ve tried multiple different styles and none of them ever seem to work. Any help is appreciated.
Proffie 2.2 with newest OS.
Post your config file.
Do you hear the sound effects? My first guess would be that you have your blade length set too long.
// ProffieOS7 Config File
#define NUM_BUTTONS 1
#define EXTRA_COLOR_BUFFER_SPACE 65
#define VOLUME 2600
#define CLASH_THRESHOLD_G 2
#define FILTER_ORDER 8
#define MOTION_TIMEOUT 60 * 2 * 1000
#define IDLE_OFF_TIME 60 * 2 * 1000
#define FETT263_MAX_CLASH 13
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#define FETT263_SWING_ON_SPEED 400
#define FETT263_SWING_ON_PREON
#define FETT263_FORCE_PUSH_LENGTH 2
{ "Skoll;common", "common/tracks/baylan.wav",
StylePtr<Skoll>(""),
"Skoll"
{ "Crispity;common", "common/tracks/cantina.wav",
StylePtr<Crispity>(""),
"Crispity"
{ "Slave;common", "slave/tracks/Pursuit.wav",
StylePtr<Slave>(""),
"Slave"
{ "Synergy;common", "common/tracks/Hyper.wav",
StylePtr<Synergy>(""),
"Synergy"
{ "Apoc;common", "common/tracks/track.wav",
StylePtr<Apoc>(""),
"Apoc"
{ "Empress;common", "common/tracks/darkside.wav",
StylePtr<Fire>(""),
"Empress"
{ "Duality;common", "common/tracks/cantina1.wav",
StylePtr<Duality>(""),
"Duality"
{ "IgRedux;common", "IgRedux/tracks/track.wav",
StylePtr<IgRedux>(""),
"IgRedux"
{ "Senate;common", "common/tracks/sheev.wav",
StylePtr<Senate>("~ ~ ~ ~ 1500"),
"Senate"
{ "CODA;common", "common/tracks/Hyper.wav",
StylePtr<CODA>(""),
"CODA"
#ifdef CONFIG_STYLES
/*--------------------------------- Synergy---------------------------------*/
using Synergy =
Layers<
Stripes<300,-4500,Black,Rgb16<13896,65,22546>>,
AlphaL<StaticFire<Black,DarkOrange,0,3,0,3000,70>,Int<16000>>, TransitionLoop<AlphaL<Black,Int<0>>,TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<1500>,Int<5000>>>,AlphaL<Black,Int<0>>,TrSparkX<Rgb<200,128,128>,Int<600>,Int<200>,Int<0>>,HumpFlickerL<AlphaL<Red,Int<16000>>,5>,TrFade<1000>>>, EffectSequence<EFFECT_FORCE,TransitionEffectL<TrConcat<TrSmoothFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>,Strobe<Black,Rgb<0,0,80>,30,30>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,60>>,StaticFire<Blue,Strobe<Black,Cyan,30,30>,0,3,300>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrSmoothFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>,Strobe<Black,Rgb<0,80,0>,30,30>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,60>>,StaticFire<Green,Strobe<Black,GreenYellow,30,30>,0,3,300>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>>,EFFECT_FORCE>>, EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<16384>>,AlphaL<Black,Int<0>>>, TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrFadeX<Percentage<WavLen<>,35>>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Scale<ClashImpactF<>,Int<4000>,Int<32768>>>>,TrFadeX<Percentage<WavLen<>,65>>>,EFFECT_CLASH>, TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeInX<Percentage<WavLen<EFFECT_STAB>,30>>,AlphaL<Stripes<5000,1000,Orange,DarkOrange,Rgb<150,60,0>,Rgb<60,30,0>,Rgb<150,14,0>,OrangeRed>,SmoothStep<Int<20000>,Int<20000>>>,TrJoin<TrSmoothFadeX<Percentage<WavLen<EFFECT_STAB>,90>>,TrWipeX<Percentage<WavLen<EFFECT_STAB>,70>>>>,EFFECT_STAB>, TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>>,EFFECT_BLAST>,
BlastL<White,850,250,351>, AlphaL<TransitionEffectL<TrConcat<TrFade<300>,Rgb<255,70,70>,TrFade<300>>,EFFECT_BLAST>,BlastF<700,250,100000>>,
BlastL<White,300,350,100000>, TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,
LockupTrL<Layers< AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>>,Int<32768>>, AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>, AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<9000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>, TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>, TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>, LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrFade<150>>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_DRAG>,
LockupTrL<Layers<
AlphaL<Black,Int<16000>>, AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>, AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>, TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>, TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
LockupTrL< AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,Rgb16<20393,93,93>,DarkOrange>,Mix<TwistAngle<>,Rgb16<20393,93,93>,Orange>,0,4,5,4000,10>>,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<4000>>>, TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>,AlphaL<Red,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,TrExtend<3000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,TrFade<3000>>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>, TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<600>>,EFFECT_IGNITION>, InOutTrL<TrWipeSparkTipX<Rgb<128,128,128>,BendTimePowInvX<Int<600>,Int<180000>>>,TrWipeInSparkTipX<AlphaL<DarkOrange,Int<16000>>,BendTimePowX<WavLen<EFFECT_RETRACTION>,Int<150000>>>>, TransitionEffectL<TrConcat<TrInstant,AlphaL<DarkOrange,Bump<Int<0>,Int<10000>>>,TrFade<1000>,AlphaL<DarkOrange,Bump<Int<0>,Int<8000>>>,TrFade<500>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<500>>,EFFECT_POSTOFF>,
ColorSelect<WavNum<EFFECT_PREON>,TrInstant,
Layers< TransitionEffectL<TrConcat<TrInstant,White,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipe<75>,AlphaL<BrownNoiseFlicker<DarkOrange,Black,200>,SmoothStep<Int<16384>,Int<-1>>>,TrCenterWipe<200>,Black,TrInstant,AlphaL<Rgb16<13896,65,22546>,SmoothStep<Scale<SlowNoise<Int<8000>>,Int<0>,Int<8000>>,Int<-1>>>,TrDelay<1410>,AlphaL<Stripes<300,-1000,Black,Rgb16<13896,65,22546>>,SmoothStep<Scale<SlowNoise<Int<6000>>,Int<4000>,Int<20000>>,Int<-1>>>,TrDelay<1100>,AlphaL<Black,Int<0>>,TrCenterWipeIn<1295>,RandomBlink<30000,Rgb16<13896,65,22546>>,TrSparkX<DarkOrange,Int<300>,Int<300>,Int<0>>,AlphaL<Black,Int<0>>,TrWipe<300>,AlphaL<RandomFlicker<Orange,Black>,Bump<Int<0>,Int<35000>>>,TrFade<370>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<1125>,AlphaL<Black,Int<0>>,TrFade<300>,StaticFire<Black,Strobe<Red,DarkOrange,75,35>,0,5,0,2500,25>,TrDelay<285>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<3020>,White,TrDelay<25>,RandomFlicker<Orange,Black>,TrFade<200>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<4565>,SparkleL<DarkOrange,200,2000>,TrFade<1550>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<6115>,AlphaL<Black,Int<0>>,TrFade<1164>,StaticFire<Black,Strobe<Red,DarkOrange,75,35>,0,5,0,2500,15>,TrInstant>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<6115>,AlphaL<Black,Int<0>>,TrWipeIn<635>,Stripes<300,-1000,Black,Rgb16<13896,65,22546>>,TrWipeIn<529>,Black,TrInstant,White,TrDelay<10>>,EFFECT_PREON>>,
Layers< TransitionEffectL<TrConcat<TrColorCycle<4800,1>,Rgb16<13896,65,22546>,TrFade<100>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<1575>,AlphaL<Black,Int<0>>,TrCenterWipe<900>,RandomBlink<30000,Black,Rgb<128,0,0>>,TrCenterWipe<775>,Stripes<300,-4500,Black,Rgb16<13896,65,22546>>,TrInstant,BlinkingX<AlphaL<Stripes<3000,-4500,Black,DarkOrange>,Int<16000>>,Black,Int<100>,Int<500>>,TrDelay<800>,AlphaL<Stripes<3000,-4500,Black,DarkOrange>,Int<16000>>,TrFade<350>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<3888>,AlphaL<Black,Int<0>>,TrWipe<800>,StaticFire<Black,Strobe<Red,DarkOrange,75,35>,100,5,100,2500>,TrSparkX<DarkOrange,Int<100>,Int<100>,Int<32768>>>,EFFECT_PREON>>>, TransitionEffectL<TrConcat<TrExtendX<Int<1000>,TrSmoothFade<200>>,AlphaL<Gradient<Blue,Green>,SmoothStep<VolumeLevel,Int<-1>>>,TrSmoothFade<500>>,EFFECT_VOLUME_LEVEL>, AlphaL<TransitionEffectL<TrConcat<TrSmoothFade<500>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Scale<BatteryLevel,Int<0>,Int<35000>>,Int<-1>>>,TrDelay<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-1>>>,TrSmoothFade<1000>>,EFFECT_BATTERY_LEVEL>,Ifon<Int<0>,Int<32768>>>
add to preset as StylePtr<Synergy>()
/*--------------------------------- CODA---------------------------------*/
using CODA =
Layers<Layers<Mix<Sin<Int<3>>,AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>,Stripes<5000,-90,Mix<Int<21200>,Black,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>,Mix<Int<16384>,Black,RotateColorsX<Int<30000>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>>,Mix<Int<12632>,Black,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>>>,AudioFlicker<RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>,Stripes<5000,-90,Mix<Int<21672>,Black,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>>,Mix<Int<26736>,Black,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>>,Mix<Int<26736>,Black,RotateColorsX<Int<28000>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>>,Mix<Int<21000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>>>>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Int<31600>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>,Black>,Black,RotateColorsX<Int<31600>,RgbArg<BASE_COLOR_ARG,Rgb<30,144,255>>>,Black>,SwingSpeed<525>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<174,255,0>>,Int<0>>,TrSparkX<RgbArg<IGNITION_COLOR_ARG,Rgb<174,255,0>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<174,255,0>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<6000>>>,Int<-6000>>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<174,255,0>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<62,249,246>>,TrFade<1000>>,EFFECT_RETRACTION>,SparkleL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,255>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>,RotateColorsX<Int<3000>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>,RotateColorsX<Int<3000>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>,RotateColorsX<Int<3000>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>,RotateColorsX<Int<3000>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>,RotateColorsX<Int<3000>,RgbArg<DRAG_COLOR_ARG,Rgb<255,234,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>>;
add to preset as StylePtr<CODA>()
/*--------------------------------- IgRedux---------------------------------*/
using IgRedux =
Layers<Mix<SmoothStep<Int<16384>,Int<16384>>,Stripes<2400,-1800,RgbArg<BASE_COLOR_ARG,Rgb<13,13,13>>,Mix<Int<4000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<13,13,13>>>,RgbArg<BASE_COLOR_ARG,Rgb<13,13,13>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<13,13,13>>>>,StripesX<Int<6000>,Scale<SlowNoise<Int<2000>>,Int<-1600>,Int<-3200>>,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>>,Mix<Int<1285>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>>>,BrownNoiseFlicker<Mix<Int<1285>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>>,Mix<Int<16384>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>>,300>,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>,RandomPerLEDFlicker<Black,Mix<Int<16384>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,234,0>>>>,AlphaL<AudioFlickerL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,0,0>>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,-1455>,Int<-6000>>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<ALT_COLOR2_ARG,Rgb<244,1,1>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<244,1,1>>>,Black>,BrownNoiseFlicker<RgbArg<ALT_COLOR2_ARG,Rgb<244,1,1>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<244,1,1>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<244,1,1>>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<244,1,1>>>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrConcat<TrWipeInX<Mult<IgnitionTime<300>,Int<6553>>>,RandomBlink<30000,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Black>,TrJoin<TrDelayX<Mult<IgnitionTime<300>,Int<19660>>>,TrWipeInX<Mult<IgnitionTime<230>,Int<6553>>>>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,IntArg<EMITTER_SIZE_ARG,1000>,Sum<Int<5000>,IntArg<EMITTER_SIZE_ARG,1000>>>,Int<-3000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<19660>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrWipe<100>>,AlphaL<StripesX<Int<3000>,Sin<Int<60>,Int<-1600>,Int<-4000>>,RgbArg<PREON_COLOR_ARG,Rgb<234,108,6>>,Mix<Int<10772>,Black,RgbArg<PREON_COLOR_ARG,Rgb<234,108,6>>>,Mix<Int<24000>,Black,RgbArg<PREON_COLOR_ARG,Rgb<234,108,6>>>>,SmoothStep<NoisySoundLevel,Int<-3000>>>,TrFade<100>>,EFFECT_PREON>>;
add to preset as StylePtr<IgRedux>()
/*--------------------------------- Skoll---------------------------------*/
using Skoll =
Layers<AudioFlicker<Stripes<26000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>,Mix<Int<12600>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>,Mix<Int<18600>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,14,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<700>>,TrInstant>,RgbArg<ALT_COLOR2_ARG,Rgb<255,180,0>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>;
add to preset as StylePtr<Skoll>()
/*--------------------------------- Senate---------------------------------*/
using Senate =
Layers<Remap<SmoothStep<Int<20000>,Int<42000>>,Stripes<2400,-1600,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<4000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>,AlphaL<StaticFire<Stripes<12000,-2000,RgbArg<ALT_COLOR3_ARG,Rgb<255,59,10>>,RotateColorsX<Int<200>,RgbArg<ALT_COLOR3_ARG,Rgb<255,59,10>>>>,Mix<Int<16384>,Black,RgbArg<ALT_COLOR3_ARG,Rgb<255,59,10>>>,0,3,2,2000,8>,SmoothStep<Scale<HoldPeakF<Ifon<Scale<IsGreaterThan<SwingSpeed<500>,Int<16000>>,Int<2000>,SwingSpeed<300>>,Int<0>>,Scale<SwingAcceleration<>,Int<100>,Int<600>>,Scale<SwingAcceleration<>,Int<10000>,Int<4000>>>,Int<1000>,Int<40000>>,Int<-4000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,25,0>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<4000>>>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>>;
add to preset as StylePtr<Senate>()
/*--------------------------------- Slave---------------------------------*/
using Slave =
Layers< Mix<SmoothStep<Int<16384>,Int<4000>>,Stripes<10000,500,Rgb<0,30,80>,Rgb<0,60,180>>,Stripes<10000,-500,Rgb<0,30,80>,Rgb<0,60,180>>>,
AlphaL<Black,Int<0>>>, TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Moccasin,TrInstant,TrFade<300>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Int<18000>>>,TrFade<600>>,EFFECT_CLASH>, TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<300>,AlphaL<Stripes<5000,1000,DarkOrange,Rgb<80,60,0>,Orange,Rgb<60,30,0>,Black,DarkOrange,Orange>,SmoothStep<Int<20000>,Int<2000>>>,TrJoin<TrSmoothFade<900>,TrWipe<700>>>,EFFECT_STAB>, MultiTransitionEffectL<TrConcat<TrDelay<700>,AlphaL<Black,Int<0>>,TrFade<800>,LocalizedClashL<HumpFlicker<DarkOrange,Red,50>,2000,50,EFFECT_BLAST>,TrFade<600>>,EFFECT_BLAST>, LocalizedClashL<Blinking<White,Black,130,800>,1560,50,EFFECT_BLAST>,
LocalizedClashL<Blinking<Red,Black,130,500>,1560,15,EFFECT_BLAST>,
LockupTrL<Layers< AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>, AlphaL<BrownNoiseFlicker<Yellow,Black,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,
TrConcat<TrInstant, AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>, TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>, TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<250>>,EFFECT_LOCKUP_BEGIN>, TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<100>>,EFFECT_LOCKUP_BEGIN>, TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>, LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrFade<150>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_DRAG>, ResponsiveLightningBlockL<RandomFlicker<Strobe<White,Rgb16<21301,0,65535>,50,10>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>>, TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>,TrFade<100>>, TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>> >>,
LockupTrL< AlphaL<Mix<TwistAngle<>,Yellow,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>, SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>, TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_MELT>, TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlicker<DeepSkyBlue,White,100>,TrFade<800>>,EFFECT_IGNITION>,
InOutTrL<TrConcat<TrInstant,Layers< AlphaL<Black,SmoothStep<Scale<Trigger<EFFECT_IGNITION,Int<300>,Int<1000>,Int<500>>,Int<16385>,Int<0>>,Int<-1>>>, AlphaL<Black,SmoothStep<Scale<Trigger<EFFECT_IGNITION,Int<300>,Int<1000>,Int<500>>,Int<16384>,Int<32768>>,Int<0>>>>,TrDelay<1000>>,TrJoin<TrWipe<700>,TrWipeIn<700>>>, TransitionEffectL<TrConcat<TrInstant,Cyan,TrDelay<50>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat< TrDelay<1500>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Red,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<3000>,Int<6000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>, TrDelay<400>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Orange,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<6000>,Int<10000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>, TrDelay<200>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Black,White,100>,Bump<ChangeSlowly<SlowNoise<Int<30000>>,Int<60000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<300>,AlphaL<Red,Int<0>>, TrDelay<200>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Yellow,Red,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<10000>,Int<28000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<200>,AlphaL<Red,Int<0>>, TrDelay<500>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Orange,White,100>,Bump<ChangeSlowly<SlowNoise<Int<30000>>,Int<60000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<200>,AlphaL<Red,Int<0>>, TrDelay<100>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Red,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<5000>,Int<13000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>,
TrDelay<500>,GreenYellow,TrDelay<25>>,EFFECT_IGNITION>, TransitionEffectL<TrConcat<TrDelay<2125>,Cyan,TrFade<100>,Black,TrDelay<10>,Cyan,TrFade<150> >,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<2125>,AlphaL<White,Bump<Int<16384>,Int<32768>>>,TrFade<100>, Black,TrDelay<10>,AlphaL<White,Bump<Int<16384>,Int<32768>>>,TrFade<150> >,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<2100>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<3000>>>,TrDelay<100>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<4000>>>, TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<5000>>>, TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<10000>>>, TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>, TrSmoothFade<175>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<30000>>>, TrSmoothFade<125>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<35000>>>, TrSmoothFade<150>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<30000>>>, TrSmoothFade<75>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<8000>>>, TrSmoothFade<25>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<3000>>>,TrFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,TrDelay<25>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Scale<Trigger<EFFECT_PREON,Int<2000>,Int<1000>,Int<500>>,Int<-1000>,Int<16500>>,Int<1500>>>,TrDelay<2000>>,EFFECT_PREON>, TransitionEffectL<TrConcat<TrDelay<1100>,AlphaL<Red,Int<0>>,TrSmoothFade<700>,Black,TrDelay<100>,AlphaL<White,Bump<Int<16384>,Int<3000>>>,TrDelay<100>>,EFFECT_PREON>
add to preset as StylePtr<Slave>()
/*--------------------------------- Duality---------------------------------*/
using Duality =
/* copyright Fett263 RainbowBlade (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#RainbowBlade
OS7.14 v2.242p
Base Style: Static Rainbow Fire (Fast)
Base Color: BaseColorArg (0)
Preon Effect: Infinity Stone Collection [Color: PreonColorArg]
Ignition Effect: Lightning Strike [Color: IgnitionColorArg]
PowerUp Effect: Unstable Power Up Center Out [Color: IgnitionColorArg]
Retraction Effect: Cycle Down [Color: RetractionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Rain Effect: Rain Dent [Color: EmitterColorArg]
Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<100,0,0>>>,AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Red>,OrangeRed,300>,SwingSpeed<400>>,TransitionEffectL<TrConcat<TrInstant,Green,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<Green,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,Green,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<Green,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<Green,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Green,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastFadeL<Green,Scale<SwingSpeed<200>,Int<8000>,Int<16000>>>,SimpleClashL<Green>,LockupTrL<AlphaL<BrownNoiseFlickerL<Green,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<Green,500,500>,TrWipeInSparkTip<Green,700,500>>>;
add to preset as StylePtr<Duality>()
/*--------------------------------- Fire---------------------------------*/
using Fire =
Mix<SmoothStep<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<36000>,Scale<BladeAngle<>,Int<10924>,Int<54000>>>,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<-1>,Scale<BladeAngle<>,Int<-10000>,Int<-1>>>>,Black,Remap<Scale<RampF,Int<0>,Scale<IsLessThan<BladeAngle<>,Int<15000>>,Int<32768>,Scale<BladeAngle<0,15000>,Int<60000>,Int<32768>>>>,Layers<Mix<BladeAngle<>,StaticFire<Gradient<RotateColorsX<Int<1600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<1000>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<400>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,2,0,1800,10>,StaticFire<Gradient<RotateColorsX<Int<1600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<1200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,4,0,2200,2>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>>;
add to preset as StylePtr<Fire>()
/*--------------------------------- Apoc---------------------------------*/
using Apoc =
Layers<Layers<Mix<SmoothStep<Scale<SwingSpeed<400>,Int<6000>,Int<24000>>,Int<10000>>,Mix<Sin<Int<30>>,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<8167>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,300>,Mix<Int<4032>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,6,10,1000,2>,StaticFire<BrownNoiseFlicker<RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>>,Mix<Int<8167>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>>>,300>,Mix<Int<4032>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>>,0,6,10,1000,2>>,HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,40>>,AlphaL<AlphaL<AudioFlickerL<RotateColorsX<Int<800>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,SwingSpeed<350>>,SmoothStep<Scale<SwingSpeed<450>,Int<29000>,Int<9500>>,Int<16000>>>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<16384>>,TrInstant>,Layers<AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<49,153,20>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<49,153,20>>,Mix<Int<8192>,Black,RgbArg<PREON_COLOR_ARG,Rgb<49,153,20>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<49,153,20>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<49,153,20>>>>,RotateColorsX<Int<1200>,RgbArg<PREON_COLOR_ARG,Rgb<49,153,20>>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,AlphaL<HumpFlickerL<AlphaL<White,Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,WavLen<EFFECT_PREON>,Mult<WavLen<EFFECT_PREON>,Int<16384>>>>,40>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>>,TrLoopN<10,TrWaveX<RgbArg<PREON_COLOR_ARG,Rgb<49,153,20>>,Int<200>,Int<200>,Scale<Trigger<EFFECT_PREON,Int<0>,Mult<WavLen<EFFECT_PREON>,Int<24576>>,Mult<WavLen<EFFECT_PREON>,Int<8192>>>,Int<400>,Int<100>>,Int<0>>>>,EFFECT_PREON>>;
add to preset as StylePtr<Apoc>()
/*--------------------------------- Crispity---------------------------------*/
using Crispity =
Layers<Layers<StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<246,0,250>>,RandomPerLEDFlicker<Mix<Int<6000>,Black,RotateColorsX<Int<32000>,RgbArg<BASE_COLOR_ARG,Rgb<246,0,250>>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<246,0,250>>>>,300>,Mix<Int<10772>,Black,RgbArg<BASE_COLOR_ARG,Rgb<246,0,250>>>,0,6,10,1000,2>,AlphaL<AudioFlickerL<RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<246,0,250>>>>,SwingSpeed<400>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<ALT_COLOR_ARG,Rgb<251,255,0>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,138>,Sum<IntArg<EMITTER_SIZE_ARG,138>,Int<6000>>>,Int<-6000>>>,AlphaL<RandomBlink<10000,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>,Black>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,255,251>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrJoin<TrInstant,TrLoopN<10,TrSparkX<Mix<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,RgbArg<PREON_COLOR_ARG,Rgb<43,255,0>>,RotateColorsX<Int<5000>,RgbArg<PREON_COLOR_ARG,Rgb<43,255,0>>>>,Int<550>,Scale<Trigger<EFFECT_PREON,Divide<Int<2000>,Int<10>>,Int<2000>,Int<0>>,Int<500>,Int<100>>,Int<0>>>>>,Layers<AlphaL<BlinkingL<Mix<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,RgbArg<PREON_COLOR_ARG,Rgb<43,255,0>>,RotateColorsX<Int<5000>,RgbArg<PREON_COLOR_ARG,Rgb<43,255,0>>>>,Int<200>,Int<500>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,AlphaL<Mix<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,RgbArg<PREON_COLOR_ARG,Rgb<43,255,0>>,RotateColorsX<Int<5000>,RgbArg<PREON_COLOR_ARG,Rgb<43,255,0>>>>,SmoothStep<Int<33000>,Scale<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,Int<0>,Int<16000>>>>>,TrFade<100>>,EFFECT_PREON>>;
add to preset as StylePtr<Crispity>()
/* Generated with Fett263 Config Helper v3.10 */
Nope, no sound effects and I’m pretty sure my blade length is set correctly
Which way is your board oriented? If the USB is pointing towards the blade you need to add this define to the top of your config.
Which way is your Proffieboard mounted in the hilt?
It’s mounted in what I believe is the standard orientation, with the SD pointing away from the blade.
Hook up to Serial Monitor and type the commands for each effect, see link for list.
Arduino > Tools > Serial Monitor
See what prints out and what sounds you hear. If you have battery power on you can also view effects on blade.
So I need to have the SD card in the saber when I hook it up to do this correctly, right?
For the sounds, yes.
Ok, so here’s another issue I seem to have a lot when I’m messing around with different settings. All I did was add the // before #define DISABLE_DIAGNOSTIC_COMMANDS in my config so I could use the serial monitor, and that alone made my config have an error saying region `FLASH’ overflowed by 6080 bytes. Is that normal? Often I make changes and even if it’s a TINY change like turning one setting off in my config, it will end up making me overflow the flash. I can’t wrap my head around why that would be… From the looks of it I’ll have to remove more stuff from the config to get it to work without disabling diagnostics. (By the way, I cannot thank you guys enough for being so incredibly helpful with me as I’m trying to learn to fully make use of the proffie software <3 )
You shouldn’t need to comment out that define for those commands.
The serial monitor commands page says Note - Commands listed under the Diagnostic Commands section below only work if
#define DISABLE_DIAGNOSTIC_COMMANDS in NOT active in the config.h file.
Overflowing flash is plenty normal. Just happens when you have lots of features enabled and/or lots of presets and/or complicated blade styles.
If you need to, just temporarily comment out (you can use /* at the beginning and */ at the end to comment a large section) a preset to make some room.
Right, you’re looking at the diagnostic command section though. It’s saying commands in that section are only active if you remove the disable. The ones above it to trigger the melt, stab, etc are active even with the disable.
OH! Whoops, you are correct didn’t notice that. Thanks
Yeah just send
on
clash
stab
blast
melt
melt (again to turn off because it’s a lockup)
off
etc…
I got this all set guys, thanks again. Now I have a whole other problem because I can’t get arduino to upload to my board because of an error, I posted the details here: Zadig is dead, long live libdwi - #40 by Chris_Salvi
In general, I recommend creating a new thread when you want help.
Only add to existing threads if you can provide help.
Not a big ideal, just an FYI for next time.
