i’m struggling to get BD working with this saber ive set up, here vid of the problem im having, i find this easer that typing it all out
also a simple config im using to test
#define NUM_BLADES 3
#define VOLUME 3000
#define BOOT_VOLUME 1500
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SPINS
#define FILTER_ORDER 8
#define SAVE_PRESET
#define SHARED_POWER_PINS
#define BLADE_DETECT_PIN blade7Pin
#define FETT263_SPIN_MODE
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#define FETT263_DISABLE_QUOTE_PLAYER
#define FETT263_TRACK_PLAYER_NO_PROMPTS
#define FETT263_SWING_ON_SPEED 300
{ "The_Bane;common", "tracks/DarkSide.wav",
Preset no_blade_presets[] = {
{ "Poison;common", "tracks/DarkSide.wav",
"no blade" },
SubBladeWithStride(1, 15, 2, NULL)
, CONFIGARRAY(presets) },
{ NO_BLADE, WS281XBladePtr<144, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
, CONFIGARRAY(no_blade_presets), "nb_save" }
