I bought the survivor bundle . but i dont know how to intall correctly in the sd card the files and i also dont know how to do it in the config , i had never done anything like this before , but i did managed to delete all the all setting and make a new one to only keep the fonts i like it, i would love some help with my config . thank you so much
Starkiller.h (83.3 KB)
I don’t see any issues with the config, did you upload?
If you don’t know how to upload I suggest using this page and going step-by-step.
For the Party Mode feature you will see that the style code requires the Font to contain alt000/ through alt008/, watch the video at the top of the Library named “Phase and Alt Fonts” for how these should be set up.
NOTE: all of the videos at the top are Recommended for users as they explain many of the new features and how to set up correctly ![]()
*This style REQUIRES Alt Fonts alt000/ to alt008/ to be set up. Uses altchng.wav on change.
Once you’ve done both it should work.
