Thank you. I wasn’t sure if I should start a new thread since the topic was exactly what I was looking for (and I was talking about config info from the earlier thread)
Here’s the original Eco Hero config that I got from Kal. Not entirely sure the preferred method of posting it on this forum it, so I’ll just paste it in below. There LEDs come on with power-up and stay on for a while after blade retraction. The code from the earlier thread has them turn on when the blade is activated and turn off after the blade retracts (preferred behavior) but in both cases they just stay on.
Thanks!
#define NUM_BLADES 3
#define VOLUME 2000
#define CLASH_THRESHOLD_G 2.5
#define SAVE_COLOR_CHANGE
#define SAVE_STATE
#define SAVE_VOLUME
#define SAVE_PRESET
#define ENABLE_SSD1306
#define ENABLE_SERIAL
#define IDLE_OFF_TIME 60 * 1 * 1000
// ECO Hero
{ "TheRtrn", "tracks/FnlDuel.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<BladeAngle<>,Int<500>,Int<200>>>,TrWipeInX<Scale<BladeAngle<>,Int<800>,Int<300>>>,Black>>>(),
StylePtr<InOutHelper<White, 1, 1, Sequence<White, Black, 200, 30, 0b1010101010101010,0b1000000000000000>>>(),
StylePtr<InOutHelper<Blinking<Black,White,1500,500>, 1, 1, Sequence<White, Black, 200, 30, 0b0000000000000000,0b0010101010101000>>>(),"the\nreturn"},
{ "Battery", "tracks/.wav",
&style_charging,
StylePtr<InOutHelper<Blinking<Black,White,1500,500>, 1, 1, Sequence<White, Black, 200, 30, 0b0000000000000000,0b0010101010101000>>>(),"Battery\nLevel"},
{ 0, WS281XBladePtr<132, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
WS281XBladePtr<1, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
, CONFIGARRAY(presets) },
