I created a font , with similar hum with the lighting sound effect . very similar to this one https://www.youtube.com/watch?v=Gn_sAlcubcg
is there a way to create a similar blade styles , I was checking in the library but I dont know what should i do that will give a lighting effect or spark like that .
i will apreciate any help , thank you
I don’t see much activity in the base style, so you could probably just do a Static Blade, then add an “Sparkle / Rain” Accent Overlay.
https://www.fett263.com/fett263-proffieOS7-style-library.html#Simple
- Choose 'Static" (or a different base style if you prefer)
- On Enhancements screen, set Base Color to Red
- In “Base Style Accent Overlay” set Overlay 0 to “Sparkle / Rain”
- Set “Full Blade” and “Random Loop”
- Set Intensity to “12” (or around there)
- Set Size to “24000”
- if you want a sound effect timed to the actual spark you can set the sound to Transition Sound and then follow the set up instructions the library provides with the style code. If you already have in the hum then it wouldn’t be needed.
- If you want a constant spark at the hilt to match you can scroll down to “Base Flare / Emitter Flare” and add a matching Flare or just let the Sparkle randomly appear at the emitter.
This should be pretty close but you can tweak and mess around with the options from there to your taste.
You can tweak it from there.
thank you so much ! looks amazing !
You’re welcome, glad to hear
