I’ve been trying to create a custom battery indicator style. I used Fett263’s style library as a base to try and understand how it works. I took what I thought to be the battery indicator part of the code and tried to turn it into a singular style:
Yes, anything that ends in an “L” is a transparent layer, so it can’t be the Base layer of a style (first color). Can’t recall where it’s documented, Layers<> have been around for years.
Also, a solid color can’t go on top of another solid color.
So essentially the rule of thumb is base layer solid (a non-L layer), everything else on top of that is a transparent layer.
What about effects? I can’t seem to find where they are defined in the code. I can infer some of them by name (i.e. EFFECT_BLAST is triggered when the blast button is pressed) but some of them I’m not sure. For instance what triggers EFFECT_BATTERY_LEVEL?
