I’m attempting to edit my blade styles and following a tutorial on YouTube
Specifically this one.
Anyways, I’ve gotten to the point where I’m attempting to find my customized config file and no matter what I do, the ardino app cannot find the file, even though it’s in the config folder. Any advice?
I am, as far as I can tell at least. I moved my configuration file into Proffie OS config folder.
I actually got it to compile without giving me any sort of error message (or anymessage at all really), and when I attempt to upload it gives me the “1234 etc” problem mentioned in the video.
If you’re getting a 1-10 count then FAIL, you likely didn’t choose the board under Arduino menu Tools>Port.
This is different than No such file or directory.
So what’s actually ahppening?
Hello again. I ended scrapping that proffie os file, and starting from scratch. Again, im running into the problem where the file says it cannot be found in the config folder. I’ll reply pics with my process
I am sure that arduino is set to proffieboard v2 when verifying the code.
