Greyscale blade Style
hi guys. trying to add some greyscale fonts to my saber. getting error message adding them to preview. after re reading the notes in the txt I think I have to delete some lines from the style. I’m pretty new to this so not really sure which to delete. any help would be greatly appreciated.
ill add the blade style text below.
Apocalypse
Hello! Below you’ll find the blade style code for the font. But first, a few notes, and a few tips and tricks for those of you that aren’t Proffie experts (yet!), I’m not claiming to be an expert, I’m still learning too :slight_smile:
These are heavily customized styles built using Fett263’s Style Library and Fredrik’s Style Editor:
Redirect
Style Editor
You’ll notice a lot of notes after “//” that I’ve added, please read through them if you want to take full advantage of the style!
“//” is used to “comment out” the code, meaning Arduino and the Style Editor skip it. You can copy the style below into your config exactly how it is and it will work fine if that’s what you choose to do.
You can edit this code yourself! Simply add or remove “//” at the beginning of the lines to add or remove them. You’ll notice a lot of optional or alternative effects! (You can even try out effects from other styles!)
Are you using a one button setup? Or a prop file other than Fett263’s? Make sure to comment out the lines mentioning his prop file (Power Save and Battery Level) to save memory! Or replace the on-demand battery with the passive battery!
If you comment out the last line (like a preon or battery level), then make sure you also remove the comma at the end of the previous line. Don’t forget to put it back if you un-comment out the last line!
You can also copy and paste it into the Style Editor mentioned above and edit it even further.
EffectSequence and BatteryLevel don’t work in the Style Editor just yet, so make sure to remove those lines when trying to edit this style in the editor.
Most styles have just 3 lines for the Multi-blast, Power Save, and On-Demand Battery Level, but some also use it for Force/Swing effects, among other things. Just ctrl-f for EffectSequence and/or BatteryLevel.
Every style has been modified to work with Color Change! Some styles will have alternate or optional code in some places depending on how everything looks (like some fire effects, or some places where the default looks good but I didn’t like how other colors looked).
 StylePtr<Layers<
  Mix<SmoothStep<Scale<SwingSpeed<400>,Int<6000>,Int<24000>>,Int<10000>>,Mix<Sin<Int<30>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<30,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<125,0,0>>,40>>,
  //Swing responsive humpflicker/rotating red/orange unstable base, unstable takes over the blade the harder you swing
  //HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,
  //Alternate plain humpflicker
  AlphaL<AlphaL<AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,8729,0>>>,SwingSpeed<350>>,SmoothStep<Scale<SwingSpeed<450>,Int<29000>,Int<9500>>,Int<16000>>>,
  //Responsive edge audioflicker swing - starts at the tip and takes over the blade the harder you swing
LockupTrL<Layers<
  AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
  AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<500>>,TrConcat<TrInstant,White,TrFade<600>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<65535,8729,0>>,TrFade<525>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<35913,7294,0>>,TrFade<250>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<100>,RotateColorsX<Variation,Rgb16<20393,1818,0>>,TrBoing<950,3>>,SaberBase::LOCKUP_NORMAL>,
  //Responsive lockup with unstable cooldown
  //AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<3000>>,SaberBase::LOCKUP_NORMAL>,
  //Alternate normal endlock effect
  //Responsive lightning block
  ResponsiveStabL<RotateColorsX<Variation,Orange>>,
  //Responsive stab
  //ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
  //Alternate responsive blast
  ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
  //Responsive Clash
  //ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
  //Alternate white clash
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Orange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<70,25,5>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<75,20,5>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<65,15,0>>>>,TrFade<2500>,Stripes<3000,-2250,RotateColorsX<Variation,DarkOrange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,15,0>>,RotateColorsX<Variation,Rgb<50,15,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<85,15,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<95,15,0>>>>,TrFade<1000>,Stripes<3000,-1500,RotateColorsX<Variation,Rgb16<65535,8729,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,10,0>>,RotateColorsX<Variation,Rgb<55,5,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<185,10,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<255,13,0>>,RotateColorsX<Variation,Rgb<105,3,0>>>>,TrFade<2500>>,EFFECT_IGNITION>,
  //Unstable ignition
  TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<255,75,0>>,40>,TrFade<500>>,EFFECT_RETRACTION>,
  //Humpflicker retraction
  //Drag
  //Responsive melt
  InOutTrL<TrWipeSparkTip<White,175,250>,TrColorCycle<500>>,
  //Spark tip ignition, cycle down retraction
  TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<White,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<500>,Int<5500>>,Int<-4000>>>,TrFade<1100>>,EFFECT_RETRACTION>,
  //White flicker retraction effect
  TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<1600>,AlphaL<RotateColorsX<Variation,Orange>,Bump<Int<0>,Int<8000>>>,TrFade<1400>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrFade<1000>>,EFFECT_RETRACTION>,
  //Emitter cool off retraction effect
  TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb16<14386,0,0>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,DarkOrange,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelay<6500>>,EFFECT_PREON>,
  //Noise responsive preon
  TransitionEffectL<TrConcat<TrDelay<3000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<115>,Int<400>,Int<250>,Int<0>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<215>,Int<300>,Int<395>,Int<0>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<345>,Int<200>,Int<500>,Int<0>>>,TrDelay<1500>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>,
  //Charge up, wave out preon
 TransitionEffectL<TrConcat<TrFade<1500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Red>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Orange>,15>,Bump<Int<0>,Int<5000>>>,TrFade<2500>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>
  //Emitter heat up preon
FWIW, I already have an optimized version of this style on the library that will not only save space but allow you to edit. Just select from the Dropdown under Greyscale Styles.
https://www.fett263.com/fett263-proffieOS7-style-library.html#Greyscale
thanks ill check it out.
