I have returned to seek help from the hive mind. I’ve been building a ESB graflex to try to get it as close to the hero prop as I can and when I bought the graflex it had some distinctive issues upon arrival I placed the battery in the chassis and then I installed the blade. The connection was solid and it worked perfectly but when I turned it on the blade stuttered ALOT. No it isn’t a blade profile but it “struggled” to actually play the animation. The sound was super choppy and buggy and it wouldn’t play correctly. I assumed it was bc it was new and it had just simply not turned on in a long time so I replaced the battery for an exact battery assuming it could’ve been the culprit. Upon swapping the battery which was also fully charged it still did the same. After a few hours of trying to figure out what the issue was my “solution” was to copy the files and paste them on a folder and format the sd card. Later reinstalling the files onto the SD card and relaunching it. It worked and fixed the glitchy issue only that after like half a year later it starts doing it again. I’d like to know if this is just a thing that happens from time to time? I’ve also had this similar issue with a different saber but not as bad. Same symptoms just not as bad as the graflex.
Yes, this is “normal.” Minor corruption and (to a probably lesser degree) fragmentation will impact the performance of the SD card (and so the performance of the saber as a whole), even if it still works, and it’s very easy to corrupt SD cards, so this sort of thing is pretty common. Reformatting and re-copying the files fixes either or both of those issues, so that’s why it fixes things.
A SD card whose baseline performance is worse would reasonably be expected to be worse under suboptimal conditions compared to a better one, so that’d be my explanation for why it seems better or worse on your other saber, aside from differences in blade style that impact performance also.
SD cards also develop problem with age. A few bits stops working will cause the SD card to have to employ some complex algorithms to recover the data, depending on the card, those algorithms can slow down reading the data significantly. Some cards will automatically recover when this happens, some don’t. The format-and-rewrite thing will fix the broken bits, but it may happen again. Getting a different and/or better SD card can sometimes be a better solution.
Please note that all SD cards die eventually. Keep a backup!
