Hello all! I found this site while researching building a fancy lightsaber.
I have always loved Star Wars, and I finally have a project I feel worthy of posting.
I stumbled upon empty hilts after seeing awesome chassis in your tube videos over the years. I settled on a Graflax and start the process of lots of learning. I didn’t know what a chassis was, neopixel, cree led, sound boards, etc. After finding the Korbanth Graflex 2.0 for a good price, I decided this would be a good starter to learn saber building.
I found Goth 3designs after that and found out he designed the awesome chassis I had been seeing over the years! While expensive thru shapeways, I decided to do it! I started planning a master build.
Alright with the story out of the way, here is the start of the build. It will be a slow process.
Korbanth kit pared down to my build. I am going with TFA version.
I 3d printed a guide and added the rails and rivets (not from the kit, they were screws)
Also riveted the kobold ring.
First shipment arrived from The Saber Armory. I am going to use a proffie board and neopixel blade/plug. Bottom item is a glass eye for the bottom. Not sure if I will illuminate it, but I am planning too so far.
Got my first batch of shapeways master chassis parts. the main frame so I can get started fitting it.
I found the battery holder is quite a bit different from the one in the videos and Goth instructions. it is a lot thinner and appears to be able to hold a proffie. I know it doesn’t go there (for me anyway) because there is a dedicated chassis part just for it. The black one in the first pic. I had to do a lot of sanding and fitting in order to get it into the korbanth aluminum frame. To the point I thought it wouldn’t fit, but I did get it.
That’s all for now. While I am waiting on the rest of the shapeways parts, I plan on assembling the electronics on the bench for testing.
Posted on the rpf as well.
