I got passed the Proffie 6.7 issue I had. I got a successful upload of my configure with my soundfonts and blade styles. It uses Fett’s two button. It’s great but I noticed my Thrust on and Twist off gesture controls are not working. Here is a copy of my Top Config:
Are you sure you’re doing the gesture of Twist Off correctly? It should be a quick twist of the hilt forward then backward once, like a rev on a motorcycle. Typically when users are having trouble they are not doing the gesture correctly. It’s diagramed at bottom of this page.
Thanks. I always do something simple stupid! I fixed the thrust gestures. Still cant get the twist off to work. Not sure what I’m doing wrong. Saw on another board that sometimes it could be the clash threshold?
Nope, not related in any way to clash threshold, not sure who would have given that advice but it’s incorrect. It’s a compound movement, turn your hilt approximately a quarter turn in one direction and then back a quarter turn in the opposite direction in quick succession. Just about every user who I’ve dealt with who has trouble with it is simply doing the gesture wrong, once they do it correctly it “magically” works
