Hey y’all. It’s my first time trying something like this. Recently picked up an 89saber from CCsabers and am trying to add fonts and styles purchased from Jay Dalorian. Original sd card the blade came with didn’t have the config so I got it from ccsabers website. Ive got proffieos and artuino installed and set up from following tutorials. The pack I got from Jay came with 4 different blade styles, and each either their own sublime code. My questions are:
If I were to create a new set in my config given the name “QGJ” could I add all 4 blade styles to it or can only 1 go into a set?
Secondly, the sound fonts that came with what I got from Jay are all audio files. But if I add these into a “QGJ” folder and place that folder into the sd card will the config be able to pull those audio files? Or is there something else I have to do?
I can add pics of whatever for clarification or I can try and explain more! I appreciate any help.
Hi Poshyposh,
Welcome to the community! You should read through all the documentation and read through FETT263’s instructions ( Fett263 Updating Your Proffieboard Instructions).
Here are some concepts for you–in the config file, there are presets, each preset defines a sound font and blade styles. In this context, anything that lights up is a blade–so your configs may have more than one blade style per preset, but only one will be for the main blade–the others will be for things like illuminated buttons and crystal chambers. (unless you have an independently controllable blade such as the tritium or KRv1–but probably not).
If you want to use different styles with the same sound font, you can duplicate the preset–maybe change the name a little, and use a different style. The link above will walk you through everything step by step–and there are more instructions here: ProffieOS
may the force be with you.
1 per preset
That is all you need to do.*
- The font might come with different options for different sound boards, if so, the QGJ directory should contain the files from the “proffieboard” folder inside your font zip file.
Thank you everyone for the feedback and clarification! I really appreciate it. This makes sense.
