Font Directory Not Found
Ok, I’ve read a few posts here regarding this issue, but I am brand new to the world of proffieboards and I am completely lost on this issue. My factory installed fonts work fine, but the fonts and config directories I copied from my other proffie doesn’t work. I’ve seen threads saying I need to add a common folder, but I’m not sure what that means.
I decided to switch it to the Fett263 setup and add the fonts from my other proffie. Here is that config:
#define NUM_BUTTONS 1
#define VOLUME 2000
#define CLASH_THRESHOLD_G 2.5
#define FETT263_TWIST_ON
#define FETT263_SWING_ON
#define FETT263_THRUST_ON
#define FETT263_MULTI_PHASE
#define SAVE_STATE
#include "..//props/saber_fett263_buttons.h"
{"Count_TOTJ", "tracks/Count_TOTJ.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<Moccasin,Rgb<255,150,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"One_Below", "tracks/One_Below.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<Moccasin,Rgb<255,150,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Ben", "tracks/Ben.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Darth", "tracks/Darth.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Third", "tracks/Third.wav",
StylePtr<Layers<HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Beq", "tracks/Beq.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Snips", "tracks/Snips.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<50,50,75>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Specter", "tracks/Specter.wav",
{"Vergence", "tracks/Vergence.wav",
{"Nomad", "tracks/Nomad.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Blind_Cowboy", "tracks/Blind_Cowboy.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,180,50>,LemonChiffon,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<LemonChiffon,Rgb<255,180,50>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Staple_Sword", "tracks/Staple_Sword.wav",
{"Loth_Hero", "tracks/Loth_Hero.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,180,50>,LemonChiffon,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<LemonChiffon,Rgb<255,180,50>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Desert_Rat", "tracks/Desert_Rat.wav",
{"Crimson_Leader", "tracks/Crimson_Leader.wav",
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Red>,Pulsing<RotateColorsX<Variation,Rgb<90,0,0>>,RotateColorsX<Variation,Red>,800>,RotateColorsX<Variation,Red>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<160,0,0>>>,TrDelay<30000>,RotateColorsX<Variation,Red>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<Moccasin,Rgb<255,150,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Decieved", "tracks/Decieved.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<1060>,Black>>>()},
{"Chosen_One", "tracks/Chosen_One.wav",
{"Dark_Lord", "tracks/Dark_Lord.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,180,50>,LemonChiffon,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<LemonChiffon,Rgb<255,180,50>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,1000>,TrWipeIn<1060>,Black>>>()},
{"Negotiator", "tracks/Negotiator.wav",
{"Shadow_Hunter", "tracks/Shadow_Hunter.wav",
{"Grandmaster", "tracks/Grandmaster.wav",
{"Emperor", "tracks/Emperor.wav",
{"Prodigal_Son", "tracks/Prodigal_Son.wav",
{"Tragedy", "tracks/Tragedy.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Survivor", "tracks/Survivor.wav",
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Blue>,Pulsing<RotateColorsX<Variation,Rgb<0,0,90>>,RotateColorsX<Variation,Blue>,800>,RotateColorsX<Variation,Blue>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,160>>>,TrDelay<30000>,RotateColorsX<Variation,Blue>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"2nd", "tracks/2nd.wav",
StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<50,0,0>>,RotateColorsX<Variation,Red>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Dark_Ruler", "tracks/Dark_Ruler.wav",
StylePtr<Layers<AudioFlicker<BrownNoiseFlicker<Mix<SwingSpeed<400>,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<150,150,225>>>,Stripes<5000,-300,RotateColorsX<Variation,Rgb<25,25,55>>,RotateColorsX<Variation,Rgb<75,75,120>>,RotateColorsX<Variation,Rgb<10,10,20>>,RotateColorsX<Variation,Rgb<50,50,75>>>,300>,RotateColorsX<Variation,Rgb<35,35,75>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Angry_Boy", "tracks/Angry_Boy.wav",
StylePtr<Layers<Stripes<2000,-2500,RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<30,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Rgb<30,0,0>>>>,TransitionLoopL<TrConcat<TrWaveX<RandomFlicker<RotateColorsX<Variation,Red>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Azure>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Azure,White,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<White,Azure,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<800>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"F1Pod", "tracks/F1Pod.wav",
StylePtr<Layers<Layers<AudioFlicker<RotateColorsX<Variation,HotPink>,RotateColorsX<BlinkingF<Int<1000>,Int<500>>,Rgb<50,0,150>>>,TransitionLoopL<TrWaveX<RandomPerLEDFlickerL<White>,Int<250>,Int<100>,Int<200>,Int<0>>>,TransitionLoopL<TrWaveX<StrobeL<White,Int<15>,Int<1>>,Int<350>,Int<100>,Int<300>,Int<0>>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrColorCycle<1000>>>>()},
{"ANH_Graflex", "tracks/ANH_Graflex.wav",
{"Obi4", "tracks/Obi4.wav",
{"ANH_Vader", "tracks/ANH_Vader.wav",
{"Stardust", "tracks/Stardust.wav",
StylePtr<Layers<Stripes<3500,-3000,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,60,0>>,RotateColorsX<Variation,Rgb<50,255,50>>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,180,50>,LemonChiffon,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<LemonChiffon,Rgb<255,180,50>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Green>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<350>>,EFFECT_PREON>>>()},
{"ESB_Graflex", "tracks/ESB_Graflex.wav",
{"ESB_Vader", "tracks/ESB_Vader.wav",
{"ROTJ_Vader", "tracks/ROTJ_Vader.wav",
{"Mother", "tracks/Mother.wav",
StylePtr<Layers<StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,20,0>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<0,120,0>>,Black>>,RotateColorsX<Variation,Rgb<0,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,50,0>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,96,0>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,128,0>>,RotateColorsX<Variation,Rgb<0,5,0>>,3000>>,AlphaL<StyleFire<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,2,0>>,0,1,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Green>,Black>,Black,RotateColorsX<Variation,Green>,Black>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<1500>,TrWipeIn<1000>,Black>>>()},
{"White_Wolf", "tracks/White_Wolf.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<128,34,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Baddie", "tracks/Baddie.wav",
{"Werewolf", "tracks/Werewolf.wav",
{"Ronin", "tracks/Ronin.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<1000>,TrWipeIn<1400>,Black>>>()},
{"Battle1", "tracks/Battle1.wav",
{"Battle2", "tracks/Battle2.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<90,65,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<Moccasin,Rgb<255,150,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Battle3", "tracks/Battle3.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<48,0,105>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<Moccasin,Rgb<255,150,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
{"Kaboom", "tracks/Kaboom.wav",
StylePtr<Layers<Layers<Mix<SmoothStep<Int<16384>,Int<4000>>,Stripes<10000,200,Rgb<0,20,90>,Rgb<0,50,240>>,Stripes<10000,-200,Rgb<0,20,90>,Rgb<0,50,240>>>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<600>>,EFFECT_IGNITION>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrJoinR<TrWipe<300>,TrWipeIn<300>>,TrJoin<TrWipe<5000>,TrWipeIn<5000>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Pulsing<Rgb<0,50,240>,Rgb<0,50,240>,400>,Bump<Scale<Trigger<EFFECT_PREON,Int<3000>,Int<1500>,Int<1500>>,Int<0>,Int<16384>>,Int<8000>>>,TrDelay<3000>,Mix<Bump<Int<16384>,Int<8000>>,Black,Rgb<0,50,240>>,TrJoin<TrWipe<1500>,TrWipeIn<1500>>,Mix<Bump<Int<16384>,Int<8000>>,Black,Rgb<0,50,240>>,TrDelay<160>>,EFFECT_PREON>>>()},
{"Deceived", "tracks/Deceived.wav",
{"TwinIon", "tracks/TwinIon.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeIn<500>,Black>>>()},
 { 0, WS281XBladePtr<129, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
What do I need to change to get my saber to read ALL of the fonts, and not just the stock ones?
This doesn’t get double slashes. That tells the compiler to ignore everything after //, so you’ve no prop file defined.
Just make it
Secondly, using the fett263 prop (or just in general) you’ll want to append a voicepack common folder to the font path in all of your presets, like
{"Count_TOTJ;common",
Read more here:
Default voicepacks are available here:
or custom ones here:
I guess my confusion comes from the fact that some packs work but others don’t, and they appear to be set up the exact same. Take for instance my first font, Count_TOTJ. It came preinstalled on the saber and works just fine. Then look at the Negotiator font I copied from my girlfriend’s single button saber, and pasted to my single button saber. It gives me the “Font Directory Not Found” notification when I select it as my font. I copied the sound folder from her saber, and then copied the config for that font from her config and pasted it to mine. The preinstalled fonts don’t have the “common” folder but yet they work.
Did you actually upload the config changes to the board? You’re not just editing a config stored on the SD card, right? it doesn’t work that way.
Correct. I copied the configs from her saber and posted them to mine. Saved them. Verified through Arduino, then uploaded. The saber recognizes there is a file there because it gives the notification at spots where I know a new font should be playing.
Ok so to keep communication straight, let’s clarify some terms used.
Font - This is the sound package (folder) that contains all the sounds. It goes on the SD card.
Config File - This is the file that starts with #ifdef CONFIG_TOP and contains all the settings and presets you want to use on the saber.
Presets - These are the sections that contain a Font, track (optionally), and your blade styles.
Now, as long as the Font folder name on the SD card is exactly the same as you have it in the preset, it will be found.
If the font is spelled differently in those 2 places, it will not be found.
If you put the font somewhere on the SD card that is different than what you have in the preset, it will not be found. (like inside another folder)
Have you confirmed these are all good? There’s not many more reasons it would give you the Font Directory Not Found error.
Also, you can open Serial Monitor in Arduino while USB is connected and see what it prints out when you get the error. It’ll say exactly what it’s looking for there (Which will be exactly whatever you told it in the preset).
I can confirm that the spellings on the folders match the spellings in the configs/presets. When I open my sd card, there are all the folders I have added to my saber plus the folders that were preinstalled. I’m not getting error messages when I verify and upload. I sent to someone last night who also verified that the config looked good. I feel like this is probably something very simple I’m overlooking because this is my first time working with a Proffie.
Like maybe the path directory is wrong? Maybe the path directory is correct and I don’t have the folders set up correctly on my SD card?
I just don’t know why the preinstalled sounds work but the added ones don’t, when they all appear to be setup the same to me.
What does Serial Monitor say?
I’ll have to check when I get back home from work. I get off at noon and will be headed straight home to continue working on this.
