Hey all I have been searching past threads and cant seem to figure this out. I was updating my saber from 130 pixels down to 123. I made this quick change in the config file and after uploading. my board is saying “font directory not found.” any help is greatly appreciated.
Post your current entire config please.
// ProffieOS7 Config File
#define VOLUME 1950
#define CLASH_THRESHOLD_G 3
#define FETT263_TWIST_ON
{ "Noble;common", "",
/* copyright Fett263 Greyscale (Primary Blade) OS7 Style
https://fett263.com/fett263-proffieOS7-style-library.html#Greyscale
OS7.12 v1.017-p
Base Style: Noble
Base Color: BaseColorArg (0)
Retraction Effect: Run Up [Color: RetractionColorArg]
Lockup Effect: Responsive Lockup, Begin Effect: Real Clash, End Effect: Full Blade Absorb [Color: LockupColorArg]
Clash Effect: Responsive Clash [Color: ClashColorArg]
Swing Effect: Bright Swing (Scaled Full Blade) [Color: SwingColorArg]
StylePtr<Layers<Stripes<5000,-75,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RotateColorsX<Int<32000>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<8100>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,White>,Mix<Int<30000>,Black,RotateColorsX<Int<32000>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<0,0,255>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
"Noble"
{ "Crispity;common", "",
OS7.12 v1.017-p
Base Style: Crispity (Unstable Blade - AudioFlicker Swing)
Preon Effect: Reverse Power Absorb (Crispity Version) [Color: PreonColorArg]
PowerUp Effect: Unstable Power Up Forward [Color: IgnitionColorArg]
Retraction Effect: Cycle Down [Color: RetractionColorArg]
Lockup Effect: DUNE Intensity Lockup, Begin Effect: Real Clash, End Effect: Full Blade Absorb [Color: LockupColorArg]
Stab Effect: AudioFlicker Stab [Color: StabColorArg]
Clash Effect: Responsive Clash with Ripple [Color: ClashColorArg]
Emitter Effect: Unstable Flare [Color: EmitterColorArg]
StylePtr<Layers<Layers<StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,RandomPerLEDFlicker<Mix<Int<6000>,Black,RotateColorsX<Int<32000>,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>>,300>,Mix<Int<10772>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>,0,6,10,1000,2>,AlphaL<AudioFlickerL<RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>>,SwingSpeed<400>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,97,0>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<6000>>>,Int<-6000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,68,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1400,-2000,RgbArg<CLASH_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<2096>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,68,0>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<38000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,EFFECT_CLASH>,LockupTrL<AlphaL<StripesX<Int<16000>,Int<12000>,Rgb<128,0,0>,Red,Rgb<90,0,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<50000>>>,TrConcat<TrJoin<TrDelayX<Scale<ClashImpactF<>,Int<2000>,Int<100>>>,TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,AlphaL<StripesX<Int<16000>,Scale<ClashImpactF<>,Int<3000>,Int<10000>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,20,128>,Rgb<128,0,0>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,DodgerBlue,Red>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,10,80>,Rgb<90,0,0>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<50000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<600>,Int<100>>>>,TrFade<400>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,244,157>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrJoin<TrInstant,TrLoopN<10,TrSparkX<Mix<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,RgbArg<PREON_COLOR_ARG,Rgb<180,130,0>>,RotateColorsX<Int<5000>,RgbArg<PREON_COLOR_ARG,Rgb<180,130,0>>>>,Int<550>,Scale<Trigger<EFFECT_PREON,Divide<Int<2000>,Int<10>>,Int<2000>,Int<0>>,Int<500>,Int<100>>,Int<0>>>>>,Layers<AlphaL<BlinkingL<Mix<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,RgbArg<PREON_COLOR_ARG,Rgb<180,130,0>>,RotateColorsX<Int<5000>,RgbArg<PREON_COLOR_ARG,Rgb<180,130,0>>>>,Int<200>,Int<500>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,AlphaL<Mix<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,RgbArg<PREON_COLOR_ARG,Rgb<180,130,0>>,RotateColorsX<Int<5000>,RgbArg<PREON_COLOR_ARG,Rgb<180,130,0>>>>,SmoothStep<Int<33000>,Scale<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<100>,Int<0>>,Int<0>,Int<16000>>>>>,TrFade<100>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>("45951,33124,0 ~ ~ ~ ~ ~ ~ ~ 65535,17247,0"),
"Crispity"
{ "Decay;common", "",
OS7.12 v1.017-p
Base Style: Decay (Inverted Rolling Pulse with Ripple Swing)
Preon Effect: Force Drain (Decay Version) [Color: BaseColorArg]
PowerUp Effect: Unstable Power Up Forward [Color: BaseColorArg]
Retraction Effect: SparkTip Retraction [Color: RetractionColorArg]
CoolDown Effect: Unstable Cool Down Reverse [Color: BaseColorArg]
Emitter Effect: Emitter Flare [Color: EmitterColorArg]
StylePtr<Layers<Layers<StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<25746>,Black,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>>,Mix<Sin<Int<23>>,Mix<Int<19504>,Black,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>,RotateColorsX<Int<32000>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>>,Mix<Sin<Int<16>>,Mix<Int<3167>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,Mix<Int<11000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>,Mix<Int<22000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>>>,AlphaL<Stripes<1000,2000,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Black>,Black,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Black>,SwingSpeed<500>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,598>,Int<-6000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,-3500,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<8487>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<8487>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>,Black>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<8487>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>,Mix<Int<3855>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<8487>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<8487>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>,Mix<Int<3855>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<8487>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<14273>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<14273>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>,Black>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<14273>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>,Mix<Int<3855>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<14273>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<14273>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>,Mix<Int<3855>,Black,Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Mix<Int<14273>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<21845>>,TrInstant>,AlphaL<AlphaL<Mix<Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>>,BrownNoiseFlickerL<RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,Int<300>>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>,HumpFlickerFX<Scale<Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>>,Int<30>,Int<70>>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<PREON_SIZE_ARG,2000>,Scale<Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<6000>>,Int<40000>>>,Int<-3000>>>,TrExtend<4000,TrBoingX<Mult<WavLen<EFFECT_PREON>,Int<5324>>,9>>,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>,Mult<WavLen<EFFECT_PREON>,Int<8176>>>,BrownNoiseFlicker<Black,RotateColorsX<Int<1000>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>,100>,RandomPerLEDFlicker<RotateColorsX<Int<2000>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>,Mix<Int<16384>,Black,RotateColorsX<Int<2000>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,RotateColorsX<Int<2750>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>>>,Mix<Int<8172>,RgbArg<BASE_COLOR_ARG,Rgb<95,0,210>>,White>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-5000>,Int<42500>>,Int<-4000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8176>>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>("~ ~ ~ ~ 275"),
"Decay"
{ "Exalted;common", "",
OS7.12 v1.017-p
Base Style: Exalted (Unstable Blade - Ripple Swing)
Preon Effect: Pilot Light [Color: PreonColorArg]
PowerUp Effect: Unstable Power Up Reverse [Color: IgnitionColorArg]
Drag Effect: Fire Drag [Color: DragColorArg]
Emitter Effect: Random Pulse [Color: EmitterColorArg]
StylePtr<Layers<Layers<Mix<SwingSpeed<400>,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,6,10,1000,2>,AudioFlicker<RotateColorsX<Int<800>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<21760>,Black,RotateColorsX<Int<400>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>>,AlphaL<Stripes<2500,-3000,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Pulsing<Mix<Int<3555>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,68,0>>,Int<0>>,TrSparkX<RgbArg<EMITTER_COLOR_ARG,Rgb<255,68,0>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<Stripes<2000,3000,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Mix<Sin<Int<30>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<8192>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrInstant>,AlphaL<PulsingL<Mix<Int<16384>,White,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>>,Int<300>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrLoopN<9,TrBoingX<Mult<WavLen<EFFECT_PREON>,Int<2458>>,3>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
"Exalted"
{ "Ra;common", "",
OS7.12 v1.017-p
Base Style: Ra (AudioFlicker - Unstable Swing)
Ignition Effect: Cycle Up [Color: IgnitionColorArg]
Swing Effect: Unstable Swing (Scaled Full Blade) [Color: SwingColorArg]
StylePtr<Layers<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<23130>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,AlphaL<AudioFlickerL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Int<4200>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Black>,Black,RotateColorsX<Int<4200>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Black>>,SwingSpeed<350>>>,AlphaL<Stripes<2000,-3000,RgbArg<SWING_COLOR_ARG,Rgb<0,255,0>>,RandomPerLEDFlicker<RgbArg<SWING_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<8192>,Black,RgbArg<SWING_COLOR_ARG,Rgb<0,255,0>>>>,RandomPerLEDFlicker<Mix<Int<3932>,Black,RgbArg<SWING_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<SWING_COLOR_ARG,Rgb<0,255,0>>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrColorCycleX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>("~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ 27207,65535,19800"),
"Ra"
{ "Mercenary;common", "",
OS7.12 v1.017-p
Base Style: Mercenary (Smoke Blade with Ripple Swing)
Preon Effect: Sparking Absorb (Mercenary Version) [Color: PreonColorArg]
CoolDown Effect: Unstable Cool Down Reverse [Color: RetractionColorArg]
Swing Effect: AudioFlicker Swing (Scaled Full Blade) [Color: SwingColorArg]
StylePtr<Layers<Layers<StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<1265>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,1200>,Mix<SwingSpeed<200>,Mix<Int<16000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Black>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Pulsing<Mix<Int<6425>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,2000>,Pulsing<Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<642>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,3000>>,AlphaL<StaticFire<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<256>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,0,1,10,2000,2>,Int<10000>>,AlphaL<Stripes<2500,-3000,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<5654>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Pulsing<Mix<Int<2322>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Black,800>>,SwingSpeed<375>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,244,157>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,-375>,Int<-6000>>>,AlphaL<AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<0,135,255>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,135,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,135,255>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,135,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,135,255>>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,244,157>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<0,135,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrInstant>,Layers<AlphaL<AudioFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<0,135,255>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<PREON_SIZE_ARG,2000>,Int<16000>>,Int<-4000>>>,AlphaL<TransitionLoopL<TrSparkX<RgbArg<PREON_COLOR_ARG,Rgb<0,135,255>>,Int<200>,Divide<WavLen<EFFECT_PREON>,Int<8>>,Int<32768>>>,SmoothStep<Int<16384>,Int<-8000>>>>,TrInstant>,EFFECT_PREON>>>(),
"Mercenary"
{ 0, WS281XBladePtr<123, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
/* Generated with Fett263 Config Helper v3.10 */
Make sure you have the ‘common’ folder with Voice Pack added to your SD per the Set Up Instructions for my prop:
Its on there. I have never had any problems when updating the fonts. I updated the pixel numbers for a shorter blade. This is the first time I have uploaded to my board in about a year. Does it matter if the SD card is in the board when I plug it in and run arduino?
It can if you have mass storage set up. Sometimes you can finish an upload with the sd card mounted as a drive and scramble your sd data by unplugging without fully ejecting.
As soon as the upload completed, my Mac gave the “disk not properly ejected” error even tho the board remained plugged in. When I tried a second time, it did the same thing. Should I buy a new SD card?
When I plug in my board with the SD card inserted, the SD does not show up in my disks on my mac. When I plug in the SD card to the card reader, my computer sees it.
You should be able to just reformat the card and move your fonts and common folder back onto it. I use the Mac disk utility. It’s slow to show up on your desk top, so it’s connected if even it’s hot yet visible. That’s why you get the eject error. I’ve done the same many times even when trying not to, so I don’t use the mass storage setting in arduino.
how do you turn off the mass storage setting?
Before you upload go into Tools in Arduino and choose USB Type without “Mass Storage”, then upload.
Now I have a new issue. I reformatted the SD card and re-uploaded the config to the board. Now when I boot it, it says “error in Font Directory” at the same time it starts playing the bootup sfx. I can change fonts, but when I do it is very slow and it says “error in font directory” as well as the font .wav
Remove this define:
Upload
Keep saber connected and go into Tools > Serial Monitor
Type ‘effects’
It will print out the current preset sounds and any errors
Post here and we can have a look
Found vmend files: one unnumbered file SOME FILES ARE MISSING! 1 != 256 in common
Found vmbegin files: one unnumbered file SOME FILES ARE MISSING! 1 != 256 in common
Found drag files: 1-1 in subdirs in Noble
Found swingh files: 1-4 in subdirs in Noble
Found swingl files: 1-4 in subdirs in Noble
Found swng files: 1-8 in subdirs in Noble
Found lock files: 1-1 in subdirs in Noble
Found out files: 1-1 in subdirs in Noble
Found in files: 1-2 in subdirs in Noble
Found clsh files: 1-8 in subdirs in Noble
Found blst files: 1-6 in subdirs in Noble
Found endlock files: 1-1 in subdirs in Noble
Found bgnlock files: 1-1 in subdirs in Noble
Found font files: one unnumbered file in Noble
Found hum files: one unnumbered file in Noble
Found boot files: one unnumbered file in Noble
This is expected behavior. When the board reboots, the power goes away for a moment, so the SD card unmounts from the computer. That’s the same as just yanking a USB drive before “ejecting” it from the Desktop.
When using the Mass Storage option, you should always right-click and choose Eject before uploading or disconnecting USB cable.
If you upload without the Mass Storage option selected, the SD card won’t connect to the computer when you plug the board in via USB.
Anyway, since you may have corrupted the files you should just reformat the board and load your fonts back on. (you made a backup of it before, right?)
Use Sd Formatter available here:
Ugh. This thing rearing it’s ugly head again.
Are these from VoicePack C ??
I have to look up where we left off on this last time, or what the fix was (if any).
@profezzorn ?
It was this thread:
Yes voicepack C
I changed out to voice pack A and it seems to be working so far
so, so weird.
