Surprisingly, after I copied everything from my Shoto SD Card over to my Shein SD Card, ALL fonts began to work again lol. But I still need to fix this common folder issue.
I need to correct myself as this isn’t entirely true. You need a common folder in the root of your SD-Card (just pick your favorite). You can also have a common folder in many (or all) fonts folder, or have a Voicepack folder (name it whatever you like - I use ‘_VoicePack’) in the root of your SD.
You would need to change your presets like this:
{ "FontName;FontName/common", "FontName/tracks/track4.wav",
or
{ "FontName;Voicepack/VoicepackName", "FontName/tracks/track4.wav",
or
{ "FontName;Voicepack/VoicepackName/common", "FontName/tracks/track4.wav",
or
what ever folder structure you like as long as you point to the correct path for the content of your chosen voicepack/common in your presets
Buuut: as soon as you use Fett263 Edit Mode on a preset, Edit Mode will revert it to { "FontName;common", "FontName/tracks/track4.wav",for that preset.
Ok so I finally downloaded that Ahsoka CW voicepacks and copied the “common” folder into my SD card, I now have access to the edit menu with Ahsokas voice lines. Both my sabers appear to be in 100% working order without any font directory not found issues. I thank you EVERYONE involved in this post for giving me much needed guidance on fixing the errors!
