Hello,
I’m new to Proffie, and I’ve spent the weekend tinkering with my config file and sd card, and I keep running into the same problem.
I have updated my proffie OS, I have Arduino set up properly, I’ve reformatted my sd card more times than I can count, my sd card files match the name in my presets, and Arduino is giving me the greenlight for my config. I flash my proffie.ino file to my board, and I insert my SD card into my board.
The saber will turn on and use the blade styles and sound fonts as they should. However, when I switch in-between sound fonts, it gives me a “font directory not found” error. But the sound still works. Even the boot noise for the font still plays, underneath the error message. Everything works as it should. It is only the error message that persists.
The only thing I can think of is that I have too much memory used on the board. I have about 95% of the boards memory tied up.
Here is the config I’m using. I used the same config that came with my saber (TXQ saber), I just edited the presets.
