Well I was playing around with the Masterless font from Greyscale on my Sabertrio, trying to get the blade to change from Yellow to Orange. With a little help from a Reddit post i was able to do that. Unfortunately, it caused the white area on the base of the blade to turn orange as well, and I really liked the white “glow” effect. I was directed here for further assistance.
Would anyone be so kind as to look at the code and see what I may have done wrong? Just to recap, I want the blade to be mainly orange with the white base.
If you can figure this out, you have my thanks.
Original Code:
StylePtr<Layers<
Stripes<15000,-300,RotateColorsX<Variation,OrangeRed>,Pulsing<RotateColorsX<Variation,Rgb<255,111,30>>,RotateColorsX<Variation,Rgb<255,140,0>>,800>,RotateColorsX<Variation,Rgb<255,140,0>>>,
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<180,180,0>>,RotateColorsX<Variation,Rgb<113,113,0>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<255,140,0>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<RotateColorsX<Variation,Rgb<255,80,10>>,Scale<IsLessThan<SwingSpeed<300>,Int<13600>>,Scale<SwingSpeed<300>,Int<-19300>,Int<32768>>,Int<0>>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,Red,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
AlphaL<RotateColorsX<Variation,Rgb<230,180,80>>,Bump<Int<0>,Int<8000>>>,
ResponsiveStabL<Red>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<230,180,80>>>,TrFade<1200>>,EFFECT_IGNITION>,
InOutTrL<TrWipeSparkTip<White,300,40>,TrWipeIn<1400>>,
TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>>>(),
My Current Code:
StylePtr<Layers<
Stripes<15000,-300,RotateColorsX<Variation,Orange>,Pulsing<RotateColorsX<Variation,Rgb<255,97,0>>,RotateColorsX<Variation,Rgb<255,97,0>>,800>,RotateColorsX<Variation,Rgb<255,97,0>>>,
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<255,97,0>>,RotateColorsX<Variation,Rgb<255,97,0>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<255,97,0>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<RotateColorsX<Variation,Rgb<255,97,0>>,Scale<IsLessThan<SwingSpeed<300>,Int<13600>>,Scale<SwingSpeed<300>,Int<-19300>,Int<32768>>,Int<0>>>,
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,97,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,Red,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
AlphaL<RotateColorsX<Variation,Rgb<255,97,0>>,Bump<Int<0>,Int<8000>>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<255,97,0>>>,TrFade<1200>>,EFFECT_IGNITION>,
