Hello - So the power goes out sporadically on my saber, and I’m pretty sure it’s due to the battery housing.
When I originally installed it, I found that the battery housing was very tight even before gluing in the battery tabs. Maybe I should have done something different in hindsight, but basically I just put the tabs in and squeeze in the battery. Over time now I’d say it’s warped the housing a bit (it still stretches upward every time I insert the battery), but basically I’ll hear the boot sound trigger sporadically, indicating that the power went out and then back on.
One idea I’ve played with is inserting some type of cushion (maybe two-sided adhesive) between the positive battery tab and the chassis, to keep downward pressure applied to hold the tab against the battery. But then I don’t think I want to have the chassis stretching any more than it does. In any event, when I put the blade in with retention screw, that typically keeps the downward pressure in place to keep a good connection. But even then if the retention screw isn’t tight enough, the blade can slip a bit and lose that hold, and I’ve had the power go out in a couple instances. And I’ve had problems before tightening the retention screw too much and chewing up the blade.
It’s like a v-shaped tab so springy in that sense. I tried cleaning the top one but didn’t seem to make a difference (from what I read q-tip and vinegar was the suggestion ) - I’ll give the kapton tape a try
Hmm does that mean there should be a groove somewhere in the chassis where the positive tab should be sitting in? I could check again but I don’t recall seeing something like that. I just remember the battery was airtight when I put it in the battery compartment, even before putting in the tabs.
In the meantime I should be getting the tape delivered soon to see if a wrap helps
Vinegar is probably the right thing for cleaning battery contacts that have alkaline leaks on them. (That white powdery stuff.) However, since this is a li-ion battery, it’s probably not the best, especially since it can corrode the contacts.
I have one saber that seems to need an unprotected 18650 since its a little shorter. I can cram a protected one in there but it does funny stuff and I worry it will break the chassis. My other thought was maybe a flat instead of a button top?
