First time Proffie build please help
Hi my name is Aaron and I been having a real difficult time getting this to work for me I have been trying for two weeks now before I came here for help. I just dont seem to understand this proffieboard configure set up. I had some help from kr sabers with a config for my hero eco cc build. I just cant get anything right. I have been watching videos for weeks now and reading every thing I can. Please please please help me. Any help would be very very appreciated
This is my wiring diagram
I keep getting this erroe code in arduino any time I try any anything
C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region `SRAM2' not declared
C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\speci\AppData\Local\Temp\ccak7TOP.ltrans0.ltrans.o: in function `main':
C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\cores\stm32l4/main.cpp:129:(.text.startup+0x5b2): undefined reference to `setup'
C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\cores\stm32l4/main.cpp:133:(.text.startup+0x5b6): undefined reference to `loop'
Normally, when you get this error, it’s because you are trying to compile the config file instead of ProffieOS.ino. Or, possibly you just deleted most of the contents of ProffieOS.ino while messing with the CONFIG_FILE define.
Either way, I would recommend re-downloading ProffieOS, find some simple directions to follow, like these:
(or some youtube video)
Alternatively, you could try using ProffieConfig which makes some of these steps simpler.
This has nothing to to with your wiring or anything in your config (as of now anyway).
I would try uninstalling then reinstallng the Arduino Proffieboard plugin.
Goto Arduino menu Tools>Board>Board Manager, type “proffie” in the search box.
Choose uninstall.
Quit and reopen Arduino.
Go back to the same place, search “proffie” again and install version 4.6.0.
Then try uploading to the board again.
edit Listen to profezzorn :wink:
I will try anything you suggest to me. I had real difficulty installing the proffie to ardunio with the links provided I used a json file of some sorts
A note about your wiring:
The two black wires that connect to the board next to each other should be swapped, otherwise the power for the main blade will need to travel through the GND ↔ BATT- connection, which is not meant for high power.
I cant seem to get ardunio working correctly proffie does not show up in ardunio libary. this link doest work it has a error
GitHub - profezzorn/arduino-proffieboard profezzorn/stm32l4
I get this error
Error downloading GitHub - profezzorn/arduino-proffieboard profezzorn/stm32l4
So, that link seems to work just fine for me - in a browser.
I’m going to read between the lines a bit and assume that you’re getting an error from Arduino. Perhaps because you used the link you posted in the board manager instead of the link you are supposed to use…
It seems like you had arduino set up correctly earlier though…
Anyways, here are some instructions for how to set up arduino:
Let me know if that is not sufficient.
deleted arduino installed again. tried to write to board and got this error code again
C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/…/lib/gcc/arm-none-eabi/14.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region SRAM2' not declared C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\speci\AppData\Local\Temp\ccn4tgBC.ltrans0.ltrans.o: in function main’:
C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\cores\stm32l4/main.cpp:129:(.text.startup+0x5e0): undefined reference to setup' C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\cores\stm32l4/main.cpp:133:(.text.startup+0x5e4): undefined reference to loop’
opps wrong board selected
this is my error code
C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/…/lib/gcc/arm-none-eabi/14.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region SRAM2' not declared C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\speci\AppData\Local\Temp\ccixu8QH.ltrans0.ltrans.o: in function main’:
C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\cores\stm32l4/main.cpp:129:(.text.startup+0x5d0): undefined reference to setup' C:/Users/speci/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\speci\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6.0\cores\stm32l4/main.cpp:133:(.text.startup+0x5d4): undefined reference to loop’
This is the same error you started with.
It’s not a problem with Arduino, or Arduino-proffieboard, it is a problem with your ProffieOS setup.
Things to check:
  1. What version of ProffieOS are you using?
  2. Post your config file.
  3. What is your config file called?
  4. Is your config file in the config directory?
  5. In arduino, are you opening up ProffieOS.ino, or something else?
  6. Is your ProffieOS.ino about 1500 lines long?
  7. What instructions are you following?
  8. Did you set CONFIG_FILE properly? (do you even have a CONFIG_FILE?)
legacy version
file called battle
No idea how to put in config directory
open up proffieOS.ino yes
instructions by stephen powell online
// ProffieOS7 Config File
#define NUM_BLADES 4
#define VOLUME 2500
#define CLASH_THRESHOLD_G 3
#define SAVE_PRESET
#define BLADE_DETECT_PIN blade4Pin
#define FETT263_TWIST_ON
#define FETT263_FORCE_PUSH
{ "battle;common",  "battle/tracks/barge.wav",
/* copyright Fett263 Rotoscope (Crystal Chamber) OS7 Style
https://fett263library.com/early-access/#Rotoscope
OS7.14 v3.01p
Style Option
Off Behavior: Off [Color: OffColorArg]
Base Color: BaseColorArg (0)
0: crystalDragMulti0Shape - Begin: Wipe In - Style: Intensity Sparking Drag - End: Wipe Out
[Color: DragColorArg]
Melt Effect:
0: crystalMeltMulti0Shape - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
[Color: StabColorArg]
StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,AudioFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Black>>>(),
StylePtr<Black>(),
StylePtr<Black>(),
StylePtr<Black>(),
"preset0"
    WS281XBladePtr<1, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin1> >()
  , CONFIGARRAY(presets) },
What does that mean?
What’s the actual version?
Where did you download it from?
It should be called “battle.h” (but not battle.h.h, I suggest turning of “hide extension” option.)
Try watching a video that shows somoene configure a proffieboard from scratch.
good
Youtube video?
There seems to be several…
Can you provide a URL?
myconfig.h is my file …battle was my font file sorry
Arduino 1.8.19
put file in arduino called my config.h
one thing i noticed is my Arduino starts up with a blank page his shoes a file location at the top
Im getting closer I think
now my error is this only
ProffieOS:53:2: error: #error Please set CONFIG_FILE as shown above.
53 | #error Please set CONFIG_FILE as shown above.
ProffieOS:57:10: error: #include expects “FILENAME” or
57 | #include CONFIG_FILE
ProffieOS:617:10: error: #include expects “FILENAME” or
617 | #include CONFIG_FILE
ProffieOS:621:10: error: #include expects “FILENAME” or
621 | #include CONFIG_FILE
ProffieOS:625:10: error: #include expects “FILENAME” or
625 | #include CONFIG_FILE
ProffieOS:683:10: error: #include expects “FILENAME” or
683 | #include CONFIG_FILE
ProffieOS:1560:10: error: #include expects “FILENAME” or
1560 | #include CONFIG_FILE
I got it down to one error
ProffieOS:28:21: fatal error: config/CONFIG_FILE.: No such file or directory
28 | #define CONFIG_FILE “config/CONFIG_FILE.”
compilation terminated.
I GOT IT!!! thank you so so so much
hey, sorry what did you do in order to sort this please I have been trying for days :sleepy_face:
This thread has multiple problem-fix cycles, so you might have to be more specific about what your error/problem is. In fact, I recommend starting a new thread, explain what you’re trying to do, what error you’re getting and post your config file. The more information you post, the better the chance of getting a quick answer.
I’m getting the same as op, I was just wondering what he did in order to fix,
C:/Users/dante/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\dante\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region SRAM2' not declared C:/Users/dante/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\dante\AppData\Local\Temp\ccS90O6g.ltrans0.ltrans.o: in function main’:
C:\Users\dante\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6\cores\stm32l4/main.cpp:129:(.text.startup+0x5b2): undefined reference to setup' C:/Users/dante/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\dante\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6\cores\stm32l4/main.cpp:133:(.text.startup+0x5b6): undefined reference to loop’
