Very interesting reading, I think i followed it, thanks
I’m so close to getting my saber build to work, Audio is good, there’s power to both switches, they work, flashed with config, appears as proffie board on my computer in devices, but still no led’s. wiring seems ok. Not sure what to do. Battery is fully charged 4.2V . I tried to access Serial Monitor but says the port is busy?
Faulty Pogo pin connector maybe??
Are you sure it’s the right port? (Does it say Proffieboard next to it?)
If it’s busy, it means something on your computer is using it, which is weird.
I recommend two things:
- post your config so we can check that it looks reasonable
- ProffieOS Documentation: How to test if data pins are working.
Ok here goes:
#define VOLUME 2200
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define MOTION_TIMEOUT 60 * 15 * 1000 // keeps motion chip active for 15 minutes while blade is Off
#define FETT263_THRUST_ON // enables Thrust On Ignition
#define FETT263_SWING_ON // enables Swing On Ignition
#define FETT263_TWIST_ON // enables Twist On Ignition
#define FETT263_TWIST_OFF // enables Twist Off Retraction
//#define FETT263_DUAL_MODE_SOUND
#define FETT263_MAX_CLASH 16
#define FETT263_SAY_BATTERY_VOLTS
#define SAVE_STATE
#include"../props/saber_fett263_buttons.h"
{"Starkiller;common", "Starkiller/tracks/SKepic.wav",
/* copyright Fett263 CustomBlade (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#CustomBlade
OS6.7 v4.017
Color Change
Default: Unstable Rage
1: Rotoscope - Single Color (Original Trilogy)
Base Color: Rgb<255,0,0> (0)
Hold Aux and press Power to change Alt Fonts
Ignition Effect Options: Default (0): Standard Ignition, 1: SparkTip Ignition
PostOff Effect: Exit Hyperspace
Lockup Effect: DUNE Intensity Lockup, Begin Effect: Real Clash, End Effect: Full Blade Absorb
Melt Effect: Intensity Melt
Stab Effect: Normal Stab
Blast Effect (Randomly Selected): Blast Wave (Random), Responsive Blast Fade (Random), Responsive Blast Wave (Random)
Clash Effect: Real Clash V1
Emitter Effect: Emitter Flare
StylePtr<Layers<
ColorChange<TrDoEffect<TrFade<1000>,EFFECT_TRANSITION_SOUND,0,1>,Stripes<3000,-3500,RgbArg<BASE_COLOR_ARG,Red>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Red>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Red>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Red>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Red>>>>,AudioFlicker<Stripes<10000,-2600,RgbArg<ALT_COLOR_ARG,Blue>,RgbArg<ALT_COLOR_ARG,Blue>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Blue>>,RgbArg<ALT_COLOR_ARG,Blue>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Blue>>>,RgbArg<ALT_COLOR_ARG,Blue>>>,
SyncAltToVarianceL,
AlphaL<RgbArg<EMITTER_COLOR_ARG,Blue>,SmoothStep<IntArg<EMITTER_SIZE_ARG,1350>,Int<-6000>>>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Orange>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,White>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,White>>>,TrFade<300>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,EFFECT_BLAST>,
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,LemonChiffon>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,LemonChiffon>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
LockupTrL<AlphaL<StripesX<Int<16000>,Int<12000>,Rgb<128,0,0>,Red,Rgb<90,0,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<50000>>>,TrConcat<TrJoin<TrDelayX<Scale<ClashImpactF<>,Int<2000>,Int<100>>>,TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,AlphaL<StripesX<Int<16000>,Scale<ClashImpactF<>,Int<3000>,Int<10000>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,20,128>,Rgb<128,0,0>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,DodgerBlue,Red>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,10,80>,Rgb<90,0,0>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<50000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<600>,Int<100>>>>,TrDoEffect<TrFade<400>,EFFECT_TRANSITION_SOUND,1,1>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Int<12000>,Int<18000>>>,TrFade<200>,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,2,1>,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,White>,Int<16000>>,30>,TrSmoothFade<600>>>>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Aquamarine>,BendTimePowX<Int<4000>,Int<10992>>,IgnitionTime<4000>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Aquamarine>,BendTimePowX<Int<2000>,Int<10992>>,RetractionTime<>>>,
InOutTrL<TrDoEffect<TrFade<1000>,EFFECT_QUOTE,16>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Aquamarine>,BendTimePow<2000,10992>>>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>>,TrCenterWipeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>>>,Remap<CenterDistF<>,Stripes<2000,-1500,Black,Rgb<100,100,150>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>>,Remap<CenterDistF<>,Stripes<1000,-500,Black,Rgb<100,100,150>,Black>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>>>,EFFECT_POSTOFF>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>()},
{ "Mercenary;common", "Mercenary/tracks/mass.wav",
StylePtr<Layers<
//Base Fett263 Smoke Blade style
StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<15,14,0>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<90,87,0>>,Black>>,RotateColorsX<Variation,Rgb<40,40,0>>,Pulsing<RotateColorsX<Variation,Rgb<36,33,0>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<60,58,0>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<90,88,0>>,RotateColorsX<Variation,Rgb<5,5,0>>,3000>>,
//Underlying Fett263 Smoke Blade Fire layer
AlphaL<StyleFire<RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<2,2,0>>,0,1,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,
//Fett263 Ripple swing effect
AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<44,42,0>>,Pulsing<RotateColorsX<Variation,Rgb<22,20,0>>,Black,800>>,SwingSpeed<375>>,
//Fett263 Bright hard swing effect
AlphaL<RotateColorsX<Variation,LemonChiffon>,Scale<IsLessThan<SwingSpeed<675>,Int<13600>>,Scale<SwingSpeed<750>,Int<-17300>,Int<32768>>,Int<0>>>,
//Fett263 Responsive Intensity Lockup
TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,
//Fett263 Sparking Emitter Flare
AlphaL<RotateColorsX<Variation,LemonChiffon>,SmoothStep<Scale<SlowNoise<Int<2750>>,Int<1750>,Int<3750>>,Int<-4000>>>,
//Responsive Stab
ResponsiveStabL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,DeepPink>>,TrWipeInX<Percentage<WavLen<EFFECT_STAB>,50>>,TrFadeX<Percentage<WavLen<EFFECT_STAB>,50>>>,
//Fett263 Real Clash
//Fett263 Unstable bright ignition effect
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<100,100,150>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,80>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<110,115,140>>,RotateColorsX<Variation,Rgb<60,60,80>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,80>>>>,TrFadeX<Percentage<WavLen<>,65>>>,EFFECT_IGNITION>,
//Fett263 Bright Humpflicker retraction effect
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFadeX<Percentage<WavLen<>,125>>>,EFFECT_RETRACTION>,
//Fett263 Intensity Drag
//Fett263 Power Save, if using Fett263's prop file hold AUX and click PWR while ON (pointing up) to dim blade in 25% increments.
//EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<8192>>,AlphaL<Black,Int<16384>>,AlphaL<Black,Int<24576>>,AlphaL<Black,Int<0>>>,
//Fett263 White Spark Tip ignition and Color Cycle retraction
InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,8>>,TrWaveX<White,Percentage<WavLen<EFFECT_IGNITION>,25>,Int<300>,Percentage<WavLen<EFFECT_IGNITION>,8>,Int<0>>>,TrColorCycle<950,7500>>,
//Absorby charge-up preon
TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<>,33>>,TransitionLoopL<TrJoin<TrWipeIn<142>,TrSparkX<RotateColorsX<Variation,LemonChiffon>,Int<425>,Int<142>,Int<32768>>>>,TrDelayX<Percentage<WavLen<>,67>>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<>,33>,Percentage<WavLen<>,67>,Int<0>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,HotPink>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,LightPink>,RotateColorsX<Variation,LemonChiffon>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,DeepPink>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Yellow>>>,RotateColorsX<Variation,LemonChiffon>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-350>,Int<17500>>,Int<-4000>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Black,SmoothStep<Sin<Int<10>,Int<16500>,Int<14500>>,Sin<Int<7>,Int<10500>,Int<9500>>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>
>>(), "mercenary"},
{ "Apocalypse;common", "Apocalypse/tracks/Term2.wav",
StylePtr<Layers<
Mix<SmoothStep<Scale<SwingSpeed<400>,Int<6000>,Int<24000>>,Int<10000>>,Mix<Sin<Int<30>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<30,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<125,0,0>>,40>>,
//Swing responsive humpflicker/rotating red/orange unstable base, unstable takes over the blade the harder you swing
//HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,
//Alternate plain humpflicker
AlphaL<AlphaL<AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,8729,0>>>,SwingSpeed<350>>,SmoothStep<Scale<SwingSpeed<450>,Int<29000>,Int<9500>>,Int<16000>>>,
//Responsive edge audioflicker swing - starts at the tip and takes over the blade the harder you swing
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<500>>,TrConcat<TrInstant,White,TrFade<600>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<65535,8729,0>>,TrFade<525>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<35913,7294,0>>,TrFade<250>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<100>,RotateColorsX<Variation,Rgb16<20393,1818,0>>,TrBoing<950,3>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with unstable cooldown
//AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<3000>>,SaberBase::LOCKUP_NORMAL>,
//Alternate normal endlock effect
//Responsive lightning block
ResponsiveStabL<RotateColorsX<Variation,Orange>>,
//Responsive stab
//ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
//Alternate responsive blast
ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive Clash
//ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Alternate white clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Orange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<70,25,5>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<75,20,5>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<65,15,0>>>>,TrFade<2500>,Stripes<3000,-2250,RotateColorsX<Variation,DarkOrange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,15,0>>,RotateColorsX<Variation,Rgb<50,15,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<85,15,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<95,15,0>>>>,TrFade<1000>,Stripes<3000,-1500,RotateColorsX<Variation,Rgb16<65535,8729,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,10,0>>,RotateColorsX<Variation,Rgb<55,5,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<185,10,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<255,13,0>>,RotateColorsX<Variation,Rgb<105,3,0>>>>,TrFade<2500>>,EFFECT_IGNITION>,
//Unstable ignition
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<255,75,0>>,40>,TrFade<500>>,EFFECT_RETRACTION>,
//Humpflicker retraction
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,White>,BendTimePowX<Int<4000>,Int<10992>>,IgnitionTime<3000>>,TrColorCycle<500>>,
//Spark tip ignition, cycle down retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<White,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<500>,Int<5500>>,Int<-4000>>>,TrFade<1100>>,EFFECT_RETRACTION>,
//White flicker retraction effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<1600>,AlphaL<RotateColorsX<Variation,Orange>,Bump<Int<0>,Int<8000>>>,TrFade<1400>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrFade<1000>>,EFFECT_RETRACTION>,
//Emitter cool off retraction effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb16<14386,0,0>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,DarkOrange,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelay<6500>>,EFFECT_PREON>,
//Noise responsive preon
TransitionEffectL<TrConcat<TrDelay<3000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<115>,Int<400>,Int<250>,Int<0>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<215>,Int<300>,Int<395>,Int<0>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<345>,Int<200>,Int<500>,Int<0>>>,TrDelay<1500>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>,
//Charge up, wave out preon
TransitionEffectL<TrConcat<TrFade<1500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Red>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Orange>,15>,Bump<Int<0>,Int<5000>>>,TrFade<2500>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>
//Emitter heat up preon
>>() ,"Apocalypse"},
{ "Coda;common", "Coda/tracks/mass2.wav",
StylePtr<Layers<
Mix<Sin<Int<3>>,AudioFlicker<RotateColorsX<Variation,DodgerBlue>,Stripes<5000,-90,RotateColorsX<Variation,Rgb<0,55,165>>,RotateColorsX<Variation,Rgb<0,85,115>>,RotateColorsX<Variation,Rgb<0,65,145>>,RotateColorsX<Variation,Rgb<0,30,185>>>>,AudioFlicker<RotateColorsX<Variation,Rgb<0,155,255>>,Stripes<5000,-90,RotateColorsX<Variation,Rgb<0,95,170>>,RotateColorsX<Variation,Rgb<0,115,215>>,RotateColorsX<Variation,Rgb<0,145,145>>,RotateColorsX<Variation,Rgb<0,65,225>>>>>,
//Rotates ^3 times per minute between DodgerBlue and DeepSkyBlue with subtle Cyan/Blue audioflicker
//AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,95,195>>>,
//Alternate DeepSkyBlue with very subtle audioflicker
AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black,300>,SwingSpeed<400>>,
//Unstable swing
AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Black,RotateColorsX<Variation,DeepSkyBlue>,Black>,SwingSpeed<525>>,
//Unstable ripple swing
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<875>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup effect with screeching humpflicker endlock
//LockupTrL<Layers<
//AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
//AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<4000>>,SaberBase::LOCKUP_NORMAL>,
//Alternate standard lockup
ResponsiveStabL<RotateColorsX<Variation,Yellow>>,
//Responsive stab
//ResponsiveStabL<Red>,
//Alternate responsive stab, no color change
//Responsive Clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<90,180,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,26,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<90,180,255>>,RotateColorsX<Variation,Rgb<0,26,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,42,128>>,RotateColorsX<Variation,Rgb<0,26,60>>>>,TrFade<400>,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<90,180,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,26,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<90,180,255>>,RotateColorsX<Variation,Rgb<0,26,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,42,128>>,RotateColorsX<Variation,Rgb<0,26,60>>>>,TrFade<450>,HumpFlickerL<AlphaL<RotateColorsX<Variation,Rgb<90,180,255>>,Int<19000>>,25>,TrFade<2875>>,EFFECT_IGNITION>,
//Stabilize ignition effect
TransitionEffectL<TrConcat<TrFade<1125>,RotateColorsX<Variation,Rgb<90,180,255>>,TrInstant>,EFFECT_RETRACTION>,
//Slow brighten retraction effect
//Drag
//Responsive melt
InOutTrL<TrWipeX<BendTimePow<3000,96384>>,TrWipeIn<1125>>,
//Standard ignition/retraction
TransitionEffectL<TrConcat<TrFade<450>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,10>,Bump<Int<0>,Int<3000>>>,TrFade<350>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,15>,Bump<Int<0>,Int<5000>>>,TrFade<450>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,20>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,25>,Bump<Int<0>,Int<10500>>>,TrBoing<150,1>>,EFFECT_PREON>
//Overload preon effect
>>(), "coda"},
{ "Masterless;common", "Masterless/tracks/masterless.wav",
StylePtr<Layers<
Stripes<15000,-300,RotateColorsX<Variation,Yellow>,Pulsing<RotateColorsX<Variation,Rgb<200,200,30>>,RotateColorsX<Variation,Rgb<180,180,0>>,800>,RotateColorsX<Variation,Rgb<180,180,0>>>,
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Rgb<180,180,0>>,RotateColorsX<Variation,Rgb<113,113,0>>>,TrDelay<30000>,RotateColorsX<Variation,Rgb<180,180,0>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<RotateColorsX<Variation,Rgb<255,80,10>>,Scale<IsLessThan<SwingSpeed<300>,Int<13600>>,Scale<SwingSpeed<300>,Int<-19300>,Int<32768>>,Int<0>>>,
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,Red,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
AlphaL<RotateColorsX<Variation,Rgb<230,180,80>>,Bump<Int<0>,Int<8000>>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<230,180,80>>>,TrFade<1200>>,EFFECT_IGNITION>,
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,White>,BendTimePow<3000,96384>>,TrWipeIn<1400>>,
TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>>>(), "Masterless"},
{ "Decay;common", "Decay/tracks/decay.wav",
StylePtr<Layers<
StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
//Bright purple absorb effect
//StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,0,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
//Alternate darker purple absorb effect, color change friendly (for reds and such)
AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,300>,SwingSpeed<400>>,
//Unstable swing
AlphaL<Stripes<1000,2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,Black,RotateColorsX<Variation,Rgb<95,0,210>>,Black>,SwingSpeed<500>>,
//Ripple down swing
AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
//Bright hard swings
LockupTrL<Layers<
AlphaL<AudioFlickerL<Azure>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>,StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,TrFade<1225>,RotateColorsX<Variation,Rgb<160,60,255>>,TrFade<250>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with reset
AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Sparking emitter flare
//AlphaL<RotateColorsX<Variation,Rgb16<45025,0,65535>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Alternate darker sparking emitter flare, color change friendly (for reds and such)
//Responsive stab
ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,60,255>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<175,80,255>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<1650>>,EFFECT_IGNITION>,
//Bright unstable ignition
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,
//Bright HumpFlicker retraction
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,White>,BendTimePow<3000,10384>>,TrWipeInSparkTip<White,1125>>,
//Spark tip in ignition and retraction
//InOutTrL<TrWipeSparkTip<White,200>,TrWipeInSparkTip<White,1125>>,
//Alternate spark tip ignition and retraction
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrWipe<150>,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrBoing<350,2>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<9000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,Bump<Int<0>,Int<13000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<18000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<23000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,50>,Bump<Int<0>,Int<19000>>>,TrBoing<1950,9>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<400>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<115>,Int<375>,Int<115>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1750>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<450>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1450>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<4350>,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<5000>,Int<3000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,0,65535>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<56306,0,65535>>,RotateColorsX<Variation,Rgb16<21919,0,22863>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb16<33124,0,65535>>,RotateColorsX<Int<2750>,RotateColorsX<Variation,Rgb16<33124,0,65535>>>>,RotateColorsX<Variation,Rgb16<42753,14386,65535>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-5000>,Int<42500>>,Int<-4000>>>,TrDelay<7750>>,EFFECT_PREON>
//Life force drain preon
>>(), "Decay"},
{ "Noble;common", "Noble/tracks/noble.wav",
StylePtr<Layers<
Stripes<5000,-75,RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<200,120,0>>,RotateColorsX<Variation,Rgb<220,160,40>>,RotateColorsX<Variation,Rgb<170,95,0>>>,
//Slightly different shades of yellow travel very slowly up the blade
EffectSequence<EFFECT_FORCE,AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,Black,300>,SwingSpeed<475>>,AlphaL<White,SwingSpeed<650>>,AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<65535,65535,28626>>,Black,300>,SwingSpeed<550>>>,
//Force toggleable swing effects, triggering the force effect cycles through a bright unstable swing, an unstable swing, and a white swing
//EffectSequence<EFFECT_FORCE,AlphaL<Mix<Sin<Int<1>>,ColorChange<TrInstant,Red>,Green,Blue,Red>,SwingSpeed<600>>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,White,RotateColorsX<Variation,Rgb<95,0,210>>,White>,SwingSpeed<600>>>,
//Alternate swing effects, triggering the force effect toggles between unstable white ripple and color change swings
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
AlphaL<RotateColorsX<Variation,LemonChiffon>,Bump<Int<0>,Int<10000>>>,
//Bright emitter flare
//Responsive stab
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,EFFECT_IGNITION>,
//Bright HumpFlicker ignition effect
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,White>,BendTimePow<3000,10384>>,TrWipeSparkTip<White,1250>>,
//Spark tip out ignition and retraction
//InOutTrL<TrWipeSparkTip<White,350>,TrWipeInSparkTip<White,1250>>,
//Alternate spark tip out ignition and spark tip in retraction
>>(), "Noble"},
{ 0, WS281XBladePtr<140, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
There’s no data flow 0.00 on AC voltage between GND and Data1 Pad.
If you just move things to data2 does it work?
Hi Brian, Luckily the pogo has a resistor on it, I’ll give it a try, it should work right?
Resistor or not, at least look for some light. If it’s there, it is not impossible that data1 is dead.
Do I have to change anything in the config settings for Data 2?
yes, you change this:
to this:
{ 0, WS281XBladePtr<140, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
(bladePin → blade2Pin)
Success! Thank you Proffezzorn and NoSloppy Couldn’t have done it on my own.
Yikes!
spoke too soon, sorry about this, saber worked ok for half hour now I’m getting random neopixels, on ignition , on the hilt, should I add a resistor to the Data Line?
Yep.
Only data1 has a built-in resistor.
Also, make sure you’re up to date on the latest ProffieOS version 7.10.
I don’t remember seeing which version Profieboard you are using, but the update addresses some possible weird pixel glitching from data pads on a V3.
Ok thanks for the info, I’ll update straight away
