Proffie noob here!
I had to mess with this config ALOT after trying to add 2 styles.
One that I bought from Greyscale fonts had all kinds of errors when pasting it in and then one from Fett’s styles generator that also seemed to be missing ending arguments.
I somehow stumbled through making edits and trial and error compiling and got it to be error free and upload but I am still skeptical.
If anyone with mad knowledge feels like taking the time to check my config I would be very grateful! I’m sure its messy!
// ProffieOS7 Config File
#define NUM_BLADES 5
#define VOLUME 1000
#define BOOT_VOLUME 80
#define CLASH_THRESHOLD_G 3
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define SAVE_PRESET
#define FETT263_MAX_CLASH 10
{ "Protostar", "common/tracks/venus.wav",
//{ Protostar;common, common/tracks/venus.wav,
StylePtr<Layers<
//Base Fett263 Dark Orange Audioflicker
AudioFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,34,0>>>,
//Unstable Orange-Red Audioflicker Swing Effect
AlphaL<AudioFlicker<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,Black,300>,RotateColorsX<Variation,Orange>>,SwingSpeed<285>>,
//Fett263 Bright Ripple Hard Swing
AlphaL<Stripes<2000,-3250,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb<60,36,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,17,0>>,Black,800>>,Scale<IsLessThan<SwingSpeed<675>,Int<13600>>,Scale<SwingSpeed<675>,Int<-19300>,Int<32768>>,Int<0>>>,
//Fett263 Bright Sparking Emitter Flare
AlphaL<RotateColorsX<Variation,Rgb16<65535,52226,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Fett263 Responsive Intensity Lockup
TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<1950>>,SaberBase::LOCKUP_NORMAL>,
//Responsive Stab
//Fett263 Real Clash
//Fett263 White Unstable Ignition Effect
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-2500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<2400>>,EFFECT_IGNITION>,
//Bright Retraction Effect
TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,52226,0>>>,TrInstant>,EFFECT_RETRACTION>,
//Fett263 Intensity Drag
//Fett263 Dual Mode White Spark Tip Ignition and Retraction - Hold above horizontal for fast ignition or below horizontal for slow ignition.
InOutTrL<TrJoin<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>>,TrWaveX<White,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,15>,Percentage<WavLen<EFFECT_IGNITION>,75>>,Int<400>,Scale<IsLessThan<BladeAngle<>,Int<16000>>,Percentage<WavLen<EFFECT_IGNITION>,5>,Percentage<WavLen<EFFECT_IGNITION>,50>>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrWaveX<White,Percentage<WavLen<EFFECT_RETRACTION>,200>,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
//Audio responsive charge-up preon effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<EFFECT_PREON>,33>,Percentage<WavLen<EFFECT_PREON>,34>,Percentage<WavLen<EFFECT_PREON>,33>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,11439,0>>,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb16<65535,52226,0>>>,RotateColorsX<Variation,Rgb<60,30,0>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,RandomPerLEDFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb16<14386,7000,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Orange>,100>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>,
//Ripple-Out Preon Effect
TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<EFFECT_PREON>,65>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,52226,0>>,Int<115>,Int<375>,Int<250>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,35>>>,EFFECT_PREON>>>(),},
{ "Mercenary" ,"",
StylePtr<Layers<StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<10,0,0>>>,RotateColorsX<Variation,Rgb<255,25,25>>,RotateColorsX<Variation,Rgb<128,0,0>>>,RotateColorsX<Variation,Rgb<80,0,0>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<255,150,150>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<255,150,150>>,RotateColorsX<Variation,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<255,150,150>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWipe<200>,StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<10,0,0>>>,RotateColorsX<Variation,Rgb<255,25,25>>,RotateColorsX<Variation,Rgb<128,0,0>>>,RotateColorsX<Variation,Rgb<80,0,0>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,TrWipe<100>,Black,TrBoing<300,3>>,TrConcat<TrFade<2000>,DarkOrange,TrFade<2000>,Red,TrFade<2000>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Red>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<8000>>,EFFECT_PREON>>>()},
{ 0, WS281XBladePtr<117, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, blade5Pin, -1, -1, -1>(),
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, blade6Pin, -1, -1, -1>()
, CONFIGARRAY(presets) },
/* Generated with Fett263 Config Helper v2.0 */
Also this is my SD card folder structure and I am not sure if this is correct?
V3.9 board OS 7.7
Root:
Inside Common folder:
Inside a style folder:
Thanks again for taking the time!
