OK, I watched Fett263’s videos on updating your proffie board to a T and I’m slowly getting it.
I just wanted to go slow and add a simple “twist on” feature.
So all I did was:
- Dropped the config file into the proffie os config folder.
- edited the config file with sublime text by adding a #define SA22C_TWIST_ON (because my profile is using the SA22C buttons in the prop folder.
- saved the config file.
- Opened ProffieOS and added the name of my config file where it goes and removed the two // so the code is activated.
And that’s all I did.
When I ran my first compile I got this error message:
