Fett's Dimming
Is there a way to import
Fett’s 10% Blade dimming that will only dim the main blade but not the accents such as clash, lightning block, or blast as in OS 5.9 to the new OS 6.x ?
I know it was in the blade style config but the config or blade styles have changed in the library
I haven’t had a chance to bring it over to OS6, but you can just take the EFFECT_POWERSAVE layer from OS5 and add it above your base layer in OS6.
EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>
It’s on the list to be added to the library but I’ve been busy with OS7 stuff and haven’t gotten around to it yet.
