Fett's Corruption phase on multiple blades
This is one for Fett directly unless anyone else knows, but i would like to use the Osha’s pull to darkness corruption phase change, however i have 3 blades on my kylo saber, how can i get this effect to work on the other 2 because once you untick the control layer it loses those effects and falls back onto the normal phase transition which doesnt have any effect close to the corruption one so would look odd and also will only play after the special ability is done.
would appreciate any guidance, but i feel this is something that not possible unless that special ability gets made into a normal transition.
You can just use the Recipe for either KyberPhonics or JuanSith “Pull to the Darkness” and select “Main Blade” for the main blade and “Secondary / Quillion Blade” for your crossguard blade(s).
-or-
You can Build a “Multi-Phase (Special Abilities)” style for your Main Blade and set at least one Special Ability for “Change Phase (Corruption)”, then close the previewer and click the “Secondary / Quillion” button and it will keep the main blade style and Special Ability settings and apply to the crossguard style for you.
Of course, for either to work you need to make sure your font supports the expect altNNN format as noted in the comments for the style generated.
I’ve tried this, the blade doesnt work how it should, the corruption effect is not playing on the side blades because it loses the control layer and the main blade control layer doesnt tell the side blades to the do that same effect, so they just wait for the main blade to do the effect and then they change using the normal transition
I dont think this is possible, it doesnt work, it would require the corruption effect to be created as a phase transition, otherwise the secondary blades have no idea what to do when the main blade is doing the effect
when you drop the control layer on the secondary blades you lose the special effects from the style so it defaults to this (see picture) for the secondary blades but only after the special effect on the main blade is finshed, so if this is set to instant, it still waits for the special effect to complete
Post the preset you’re using. You only need one Control Layer per preset, the EFFECT is handled across all blades assuming the style code is set up correctly, unless there’s a bug in the scripts it should work as expected but it’s been a long time since I created.
StylePtr<Layers<ColorSelect<AltF,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<19276>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrExtend<12000,TrDoEffectAlwaysX<TrDelay<10>,EFFECT_TRANSITION_SOUND,Int<0>>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<2>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER3>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER4>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>,EFFECT_USER5>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<2>>,Int<-1>>,EFFECT_USER6>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER7>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER8>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrFade<100>>,AlphaL<Rgb<255,255,255>,Bump<VolumeLevel,Int<8000>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
StylePtr<Layers<Black,ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<19276>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
I need the comment section for each style the library generates to be able to troubleshoot.
OS7.15 v3.44p
Multi Phase (Special Abilities*) Transition: Instant, Time: 500
Default: Hyper Responsive Rotoscope (Original Trilogy) [BaseColorArg]
1: Hyper Responsive Rotoscope (Original Trilogy) [AltColorArg]
Multi Phase Control: use Special Abilities controls to change Phase. Requires Alt Font.
*This style REQUIRES Alt Fonts alt000/ to alt001/ to be set up. Uses altchng.wav on change.
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Stab Effect: Normal Stab [Color: StabColorArg]
Special Ability 1: Change Phase (Corruption: Rotoscope - Time: 10000 ms) Uses tr00.wav or or tr/000/000.wav (blade corruption sound)
Special Ability 2: Change Phase (Corruption: Rotoscope - Time: 10000 ms) Uses tr01.wav or or tr/001/000.wav (blade corruption sound)
StylePtr<Layers<ColorSelect<AltF,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<19276>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrExtend<12000,TrDoEffectAlwaysX<TrDelay<10>,EFFECT_TRANSITION_SOUND,Int<0>>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrExtend<12000,TrDoEffectAlwaysX<TrDelay<10>,EFFECT_TRANSITION_SOUND,Int<1>>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>>,EFFECT_USER2>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER2>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER2>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER2>>>(),
/* copyright Fett263 CustomBlade (Quillion / Secondary Blade) OS7 Style
OS7.15 v3.44p
Multi Phase (Special Abilities*) Transition: Wipe, Time: 500
Default: Master Sol [BaseColorArg]
1: Osha (Dark Side) [AltColorArg]
Lockup Effect: NoneLightning Block Effect: NoneDrag Effect: NoneMelt Effect: NoneSpecial Ability 1: Change Phase (Corruption: Rotoscope - Time: 10000 ms) Uses tr00.wav or or tr/000/000.wav (blade corruption sound)
Special Ability 2: Next Phase
Special Ability 5: Ignite + Change Phase (Corruption: Rotoscope - Delay: 1000 ms - Time: 10000 ms) Uses tr01.wav or or tr/001/000.wav (blade corruption sound)
StylePtr<Layers<Black,ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,AudioFlicker<Stripes<22000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<10000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<18000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,AudioFlicker<Stripes<25000,-1500,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10640>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<18460>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrDelay<10>,Black,TrExtendX<Int<1000>,TrWipeX<Int<300>>>,AlphaL<White,Int<0>>,TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<Subtract<TimeSinceEffect<EFFECT_USER5>,Sum<Int<300>,Int<1000>>>,327>,Int<0>,Int<28000>>,Scale<Percentage<Subtract<TimeSinceEffect<EFFECT_USER5>,Sum<Int<300>,Int<1000>,Int<10>>>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER5>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER1>>>(),
OS7.15 v3.44p
Your Special Abilities are mismatched. All blades in the preset need to have the same Special Abilities or only the Control Layer’s blade will work. See my original reply for how to set up all of the blades to match.
Only because I made this config really quick, as you wanted the commented parts, you can see my original one is all matched up
Huh? If you want me to troubleshoot styles I need the comments and styles giving you trouble. The styles you posted are missing the comments and pieces of code I’d expect to see from the library if things were set up correctly. But without the comment section on each style I can’t troubleshoot if it was the library or user error that is causing.
Go back to my original post and try what I recommended, keep the comments with the styles and test. If it still doesn’t work post what the library generated including the comments and I’ll have a look.
OS7.15 v3.44p
Multi Phase (Special Abilities*) Transition: Instant, Time: 0
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Display Volume: Blade Location [Color: Rgb<255,255,255>]
Special Ability 3: Play Quote
Special Ability 4: Play Quote
Special Ability 5: Next Phase
Special Ability 6: Previous Phase
Special Ability 7: Play Quote
Special Ability 8: Play Quote
StylePtr<Layers<ColorSelect<AltF,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<19276>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrExtend<12000,TrDoEffectAlwaysX<TrDelay<10>,EFFECT_TRANSITION_SOUND,Int<0>>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrExtend<12000,TrDoEffectAlwaysX<TrDelay<10>,EFFECT_TRANSITION_SOUND,Int<1>>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER3>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER4>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER2>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER2>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>,EFFECT_USER5>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<2>>,Int<-1>>,EFFECT_USER6>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER7>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER8>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrFade<100>>,AlphaL<Rgb<255,255,255>,Bump<VolumeLevel,Int<8000>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
OS7.15 v3.44p
StylePtr<Layers<ColorSelect<AltF,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<19276>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER2>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER2>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<1000>>,EFFECT_USER2>>>(),
wait wtf that actually works now, but how, i know you said about the special abilities have to match but when you untick the control layer it basically removes them from the style
The library handles assembling the necessary effects in to the style even when Control Layer is removed. If you match Special Abilities across blades in a preset the secondary blades and crystals will still run Special Ability effects from the main Control Layer. You just need to make sure the Special Abilities for each style match in the preset and you only have one Control Layer.
I designed the library to maintain Special Abilities for other blades if you build Main Blade first in same session.
