Fett263 Stab Effect Question
I was just curious how much strength is required to trigger the stab effect. I’m not entirely sure how the blade senses the tip of the blade on impact and i don’t want to test this by increasing stab force on my blade.
Stab uses your Clash Threshold value, it’s just looking for linear movement as well. That said there are other factors like any “cushion” your pins may provide the blade that make Stab sometimes require a little more force than a normal clash, but it’s controlled at the OS level, via CLASH_THRESHOLD_G not in the prop. If you purposefully focus on moving the blade linearly before the tip impacts it will make it easier to trigger I find.
