I’ve combed over Fett263 ProffieOS6 Prop File (Buttons and Controls) to find the answer, and to test I just havn’t had a chance yet on my new 1 button saber, but is there a specific #define to swap between the 1 or 2 button setup? Or is it literally based on whatever is defined in #define NUM_BUTTONS ?
No, that is just how you include my prop in your config. Your original question is a modification to that prop, so you need to actually open the prop file and make a simple code change.
What you posted is exactly what to look for and what to do.
Adding a simple // to comment out and disable that line.
The code to edit is in the saber_fett263_buttons.h prop file, which is in ProffieOS/props folder.
so for it to look like this
case EVENTID(BUTTON_POWER, EVENT_FOURTH_HELD_LONG, MODE_OFF):
if (menu_) return true;
//CopyPreset(true);
return true;
and this
case EVENTID(BUTTON_AUX, EVENT_CLICK_LONG, MODE_OFF | BUTTON_POWER):
//CopyPreset(true);
return true;
Yes, although only one is actually necessary depending on NUM_BUTTONS but no harm in doing both I guess. If you only have 1 button the BUTTON_AUX doesn’t apply to you saber.
It’s a plain text file. It doesn’t take any fancy formatting like fonts and highlighting.
Instead you can do like visual marker lines as comments. Sometimes I’ll do that to find a spot.
Like
Sort of an odd request, but is there a version of Fett’s prop file that does not contain the Choreography or Edit modes? No offense to Fett, I love his work, but I don’t use those functions and I was hoping to add some more elaborate blade styles with the extra space. I would use sa22c’s prop file (as Fett’s is based on that), but it doesn’t seem to perform the same as Fett’s prop file (e.i. - swing sounds are choppier).
I am moderately informed on c++, but the prop file is incredibly detailed and I’m not really sure how to achieve what I want. Thanks for any help!
