Hello, I’m working on a Saberbay Darksaber build (following these instructions), and I was testing the Proffie v3.9 board prior to install. I uploaded the included config to the board and took some measurements with a multimeter to check that everything was working as expected:
- Battery voltage nominal (~4V, matches serial monitor)
- GND to 5V and 3.3V pads both measured nominal (~5V, ~3.3V, respectively)
- Batt+ to LED2, LED3, and LED4 returned near-zero voltages
The last test is where the problem lies. From the config, I would expect these FETs to turn on, but I’m not getting the nominal ~4V. I’ve included my intended wiring diagram here as well. Notably, a single data line is used for the accent pixel and the hilt-side PCB (no LEDs, only passthrough). I used the Din and Dout pads on the accent pixel to daisy-chain the data line to the hilt-side PCB that delivers data directly to the main blade (the blade PCB has a 330 Ohm resistor on the data line). I used SubBlade in the config to mirror the wiring. The switch PCB is wired up as a npxl pcb, with it’s own pos, neg, and data lines. Does anyone see anything amiss here?
Additional note: I plan on wiring a small “2020” pixel strip as shown in the instructions, except wiring it to Batt+, LED5, and Data3 (switch PCB LEDs get power from LED4). From what I understand, it’ll be a normal WS281XBladePtr. I’ll have to add another line to the BladeConfig section, a style to each preset, and increase blade to 4 to run it. That’s separate from the issue I’m having here, but may present similar symptoms if I don’t resolve this issue.
#define NUM_BLADES 3
#define VOLUME 1200
#define CLASH_THRESHOLD_G 1.0
#define ENABLE_SSD1306
#define SHARED_POWER_PINS
//Customized Options
//Edit Mode
//Gesture Control
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_SWING_ON
//Battery
#define FETT263_MULTI_PHASE
//Motion Timeout
//Other
//Include FETT263 Prop File
// Fire speed, valid values are 1 - 10
#define FIRE1_SPEED 2
// How long to wait before firing up crossguards.
#define FIRE1_DELAY 800
// Each of these have three values: A, B, C
// A = non-random intensity
// B = random intensity
// C = cooling
// The first two control temperature, and as we add
// A + rnd(B) to the base of the blade each animation frame.
// The second controls how rapidly the fire cools down
// This is used during normal operation.
#define FIRE1_NORMAL 0, 1000, 2
// This is used when a clash occurs
#define FIRE1_CLASH 3000, 0, 0
// This is used during lockup.
#define FIRE1_LOCKUP 0, 5000, 10
// Helper
#define FIRE1PTR(NUM, DELAY) \
StyleFirePtr<RED, YELLOW, NUM, DELAY, FIRE1_SPEED, \
FIRE1_NORMAL, FIRE1_CLASH, FIRE1_LOCKUP>()
{ "MandoDarksaber;common", "common/tracks/Mandalorian.wav",
StylePtr<Layers< StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>, TransitionEffectL<TrConcat<TrFade<400>,RotateColorsX<Variation,Rgb<175,175,225>>,TrDelay<1000>,RotateColorsX<Variation,Rgb<175,175,225>>,TrFade<800>>,EFFECT_FORCE>, AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black>,White,RotateColorsX<Variation,Rgb<100,100,150>>,White>,SwingSpeed<600>>, LockupTrL<Layers< AlphaL<AudioFlickerL<Red>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>, AlphaL<Red,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>, ResponsiveLightningBlockL<Strobe<Red,AudioFlicker<Red,Black>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Red,Int<16000>>,30>,TrSmoothFade<600>>>, AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>, MultiTransitionEffectL<TrConcat<TrDelay<300>,RandomPerLEDFlickerL<Red>,TrDelay<1000>,RandomPerLEDFlickerL<Red>,TrFade<500>>,EFFECT_STAB>, AlphaL<Mix<IsLessThan<BladeAngle<>,Int<26000>>,MultiTransitionEffectL<TrConcat<TrWipeIn<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipeIn<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrConcat<TrWipe<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipe<200>>,EFFECT_STAB>>,Int<32768>>, ResponsiveBlastWaveL<Red,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>, ResponsiveBlastWaveL<Red,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>, AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<2400>>,Int<22000>,Int<40000>>,Int<22000>>>, LockupTrL<AlphaL<BrownNoiseFlickerL<Red,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>, LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>, InOutTrL<TrWipe<300>,TrWipeIn<500>>, TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<100,100,150>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_RETRACTION>, TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<100,100,150>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<100,100,150>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>(),
StylePtr<Layers<StripesX<Int<2000>,Int<-800>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<128,128,128>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<0,8,255>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2938>,Int<-6000>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
"din\ndjarin"},
{ "GideonDarksaber;common", "common/traks/GideonEmerges.wav",
"moff\ngideon"},
{ "VizslaDarksaber;common", "common/tracks/PreVizsla.wav",
"pre\nvizsla"},
{ "MaulDarksaber;common", "common/tracks/satinesdeath.wav",
"darth\nmaul"},
{ "SabineDarksaber;common", "common/tracks/Rebels Theme.wav",
"sabine\nwren"},
// Order of Blades
// - Main Blade
// - Single Pixel Crystal Chamber
// - Switch PCB Pixels
{ 0,
SubBlade(1, 108, WS281XBladePtr<108, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
SubBlade(0, 0, NULL),
WS281XBladePtr<2, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
CONFIGARRAY(presets) },
