There Is a way to save and load the fet263 configuration? Or ti load a config file for align all option in the configurator?
The config helper will keep your config stored in your browser’s local storage (so you need to use same computer and browser).
It cannot read an existing config file, there are way too many variables, it’s designed to help you build a config (and optimize it). Watch the videos at the top for how to use:
You should still always keep a copy of your config backed up somewhere (or in multiple locations).
THX for replay, I Will check It.
I configured my browser to clean cache on exit. So, evrey time I loaded the site, the config helper was reset.
Now I changed the browser configuration anche the site work correctly.
Thx.
Would there be a way to save the settings withing the browser and store configs to come back to later? I’m thinking for blade styles too, its annoying having to recreate blade styles every time I decide I want to work on something else.
The config helper tool should save configs in your browser’s Local Storage, up to 6. I only really use Chrome and it works for me, so if you’re using a different browser perhaps try Chrome.
The library doesn’t have that level of sophistication, but it will output your selections in the copyright and information section so it’s easy to recreate (or to reproduce in future libraries.)
If you want to work on new styles you can also just open a new tab with the library and leave the “in progress” style open in the background, just don’t refresh or reload the page and it’ll keep your selections ![]()
oh cool, is there a way to see what configs are in the local storage and select them?
They’d be listed at the top of the tool by name, a button is created for each new one you added up to 6, to add a new one click “add config”.
The active config is saved automatically when you Generate config and will reload from Local Storage when you come back and visit the page. The buttons at top will give you access to the others through same mechanism.
ohhhh for the config yea, is there a way to do the same with blade styles?
If you mean the library, no. There’s far too many options and customization in the library. When you generate a style in the library the copyright and information section at the top includes the selections you made so you can recreate if needed.
As long as you keep the library open and don’t refresh it will keep your selections. So you can upload and test and come back, if you need to do several styles just open a new tab with a different iteration of the library. If the animation times out in the Previewer just click the reload style button above the preview scrern, it will keep the current selections as long as the page is there, just don’t refresh the page.
