Hi there
im using ProffieOS6.5 and when ever i ignite my saber it says faston and ignites instantly
with no ignition timing, it happens to all my bladestyles except the ones that have preons?
Thanks for any advice
#define VOLUME 2000
#define CLASH_THRESHOLD_G 2.2
#define ENABLE_SPINS
#define FETT263_THRUST_ON // enables Thrust On Ignition
#define FETT263_SWING_ON // enables Swing On Ignition
#define FETT263_TWIST_ON // enables Twist On Ignition
#define FETT263_TWIST_OFF // enables Twist Off Retraction
//#define FETT263_FORCE_PUSH_LENGTH 5 // enables Force Push gesture/sound during Battle Mode
#define MOTION_TIMEOUT 60 * 15 * 1000 // keeps motion chip active for 15 minutes while blade is Off
#define FETT263_MULTI_PHASE // enables Multi-Phase preset changing while blade is ON
#define FETT263_BM_DISABLE_OFF_BUTTON // disables pwr button in Battle Mode
{ "Kenobi2", "tracks/Aniobi.wav",
StylePtr<Layers<
EffectSequence<EFFECT_IGNITION,
AudioFlicker<RotateColorsX<Variation,Rgb<0,0,128>>,RotateColorsX<Variation,Rgb<0,0,200>>>,
Mix<SwingSpeed<1>,AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Blue>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,0,25>>,RotateColorsX<Variation,Rgb<0,0,60>>>,300>,RotateColorsX<Variation,Rgb<0,0,80>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>>,
Mix<Scale<BladeAngle<>,Int<32768>,Int<0>>,StyleFire<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,60>>,0,4,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,0,0>>,StyleFire<RotateColorsX<Variation,Blue>,Black,0,2,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,0,0>>>,
Stripes<5000,-1500,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,60>>,RotateColorsX<Variation,Rgb<50,50,255>>,RotateColorsX<Variation,Rgb<0,0,128>>>
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,Bump<Int<0>,Int<8000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Blue>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Blue>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Blue>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Blue>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()},
{ "Kenobi", "tracks/Kenobi.wav",
StylePtr<Layers<
StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,80>>,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,20>>,RotateColorsX<Variation,Blue>>,
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>>>,SaberBase::LOCKUP_NORMAL>,
SparkleL<White,100,400>,
ResponsiveStabL<Red>,
ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,Int<400>,Int<100>,Int<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
InOutTrL<TrWipe<300>,TrWipeIn<500>>,
EffectSequence<EFFECT_PREON,TransitionEffectL<TrConcat<TrWipe<300>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<0,0,60>>,90>,SmoothStep<Int<2000>,Int<-500>>>,TrDelay<1000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<0,0,60>>,90>,SmoothStep<Int<2000>,Int<-500>>>,TrWipe<300>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<0,0,128>>,60>,SmoothStep<Int<4000>,Int<-500>>>,TrDelay<1000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<0,0,128>>,60>,SmoothStep<Int<4000>,Int<-500>>>,TrWipe<300>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<0,0,190>>,30>,SmoothStep<Int<6000>,Int<-500>>>,TrDelay<5100>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrDelay<1500>,AlphaL<HumpFlickerL<Rgb<100,100,150>,30>,Bump<Int<0>,Int<3000>>>,TrFade<2000>,AlphaL<HumpFlickerL<Rgb<100,100,150>,30>,Bump<Int<0>,Int<4000>>>,TrFade<2500>,AlphaL<HumpFlickerL<Rgb<100,100,150>,30>,Bump<Int<0>,Int<5000>>>,TrBoing<1950,7>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<Rgb<100,100,150>,Int<500>,Int<200>,Int<500>,Int<32768>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<Rgb<100,100,150>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<Rgb<100,100,150>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<3000>,AlphaL<Rgb<100,100,150>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Blue>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Blue>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Blue>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Blue>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>>()},
{ "Princess", "tracks/leiathm.wav",
StylePtr<Layers<Pulsing<Stripes<3000,-3000,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,10,60>>,RotateColorsX<Variation,Rgb<50,130,255>>,RotateColorsX<Variation,Rgb<0,20,128>>>,Stripes<3000,3000,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,10,60>>,RotateColorsX<Variation,Rgb<50,130,255>>,RotateColorsX<Variation,Rgb<0,20,128>>>,3000>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,2000,White,DeepSkyBlue>,Stripes<1500,-2500,White,DeepSkyBlue>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,SparkleL<White,100,400>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,500>,TrWipeIn<800>,Black>>>()},
{ "TthCrstl", "tracks/Crystal.wav",
StylePtr<Layers<StripesX<Int<50000>,Scale<TwistAngle<>,Int<-100>,Int<0>>,Red,Orange,Yellow,Green,Blue,Magenta>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrInstant,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<300>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<800>,TrWipeIn<800>,Black>,TransitionEffectL<TrConcat<TrWaveX<Red,Int<400>,Int<400>,Int<400>,Int<32768>>,AlphaL<PulsingL<Red,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<1000>,AlphaL<PulsingL<Red,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<DarkOrange,Int<400>,Int<400>,Int<400>,Int<32768>>,AlphaL<PulsingL<ColorSequence<400,Red,DarkOrange>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<800>,AlphaL<PulsingL<ColorSequence<400,DarkOrange,Red>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Yellow,Int<350>,Int<200>,Int<350>,Int<32768>>,AlphaL<PulsingL<ColorSequence<350,DarkOrange,Red,Yellow>,Int<800>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<800>,AlphaL<PulsingL<ColorSequence<350,Yellow,DarkOrange,Red>,Int<800>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Green,Int<350>,Int<400>,Int<350>,Int<32768>>,AlphaL<PulsingL<ColorSequence<350,Yellow,DarkOrange,Red,Green>,Int<700>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<700>,AlphaL<PulsingL<ColorSequence<350,Green,Yellow,DarkOrange,Red>,Int<700>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Cyan,Int<300>,Int<400>,Int<300>,Int<32768>>,AlphaL<PulsingL<ColorSequence<300,Green,Yellow,DarkOrange,Red,Cyan>,Int<600>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<700>,AlphaL<PulsingL<ColorSequence<300,Cyan,Green,Yellow,DarkOrange,Red>,Int<600>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Blue,Int<300>,Int<400>,Int<300>,Int<32768>>,AlphaL<PulsingL<ColorSequence<250,Cyan,Green,Yellow,DarkOrange,Red,Blue>,Int<400>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<600>,AlphaL<PulsingL<ColorSequence<200,Blue,Cyan,Green,Yellow,DarkOrange,Red>,Int<500>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Magenta,Int<250>,Int<300>,Int<250>,Int<32768>>,AlphaL<PulsingL<ColorSequence<100,Blue,Cyan,Green,Yellow,DarkOrange,Red,Magenta>,Int<300>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<600>,AlphaL<ColorSequence<200,Magenta,Blue,Cyan,Green,Yellow,DarkOrange,Red>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<1050>>,EFFECT_PREON>>>()},
{ "Anakin2", "tracks/TMarch.wav",
StylePtr<Layers<Pulsing<Stripes<3000,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,Stripes<3000,3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,3000>,AlphaL<RotateColorsX<Variation,Rgb<255,150,150>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrFade<400>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastL<White,Int<400>,Int<100>,Int<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,600>,TrWipeIn<800>,Black>,TransitionEffectL<TrConcat<TrWipe<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()},
{ "Bastilla", "tracks/BasThm2.wav",
StylePtr<Layers<Layers<TransitionLoop<RotateColorsX<Variation,Rgb<180,130,0>>,TrConcat<TrBoing<500,3>,Layers<Stripes<10000,100,RotateColorsX<Variation,Rgb<90,65,0>>,RotateColorsX<Variation,Rgb<20,14,0>>,RotateColorsX<Variation,Rgb<141,102,0>>>,AlphaL<Stripes<8000,-200,RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<42,31,0>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrWipe<200>,AlphaL<White,Int<0>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>>>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastL<White,Int<400>,Int<100>,Int<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWipeIn<200>,RandomBlink<30000,White,Black>,TrWipeIn<200>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,Int<1000>,Int<6000>>,Int<-3000>>,Black,White>,TrDelay<400>,Mix<SmoothStep<Int<4000>,Int<-3000>>,Black,White>,TrWipe<300>>,TrWipeIn<500>,Black>>>()},
{ "Revan", "tracks/DarthR.wav",
StylePtr<Layers<
ColorChange<TrFade<4000>,Stripes<5000,-1500,Rgb<95,0,210>,Rgb<21,0,52>,Rgb<130,40,230>,Rgb<42,0,105>>,Pulsing<Stripes<3000,-3000,Red,Rgb<60,0,0>,Rgb<255,50,50>,Rgb<128,0,0>>,Stripes<3000,3000,Red,Rgb<60,0,0>,Rgb<255,50,50>,Rgb<128,0,0>>,3000>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Sin<Int<10>,Int<10000>,Int<20000>>>>,
AlphaL<White,Bump<Sin<Int<10>,Int<10000>,Int<20000>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Sin<Int<10>,Int<10000>,Int<20000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Sin<Int<10>,Int<10000>,Int<20000>>>>,SaberBase::LOCKUP_NORMAL>,
AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,
InOutTrL<TrWipeSparkTip<White,500>,TrWipeIn<800>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<95,0,210>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<95,0,210>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()},
{ 0, WS281XBladePtr<144, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(Preset)}
