Accidentally deleted my last one. 128GB SD card is loading properly in the serial monitor for two of my proffie v3.9 boards but gives me the “failed to mount SD card” error on my v2.2. Not sure if there’s any workaround here since signs are pointing to a faulty SD card reader. Any help appreciated, thanks!
Configs for the v2.2 and v3.9 boards, if that helps at all.
owkv3.h (7.9 KB)
owkv2.h (7.9 KB)
V2 boards have had some weird problems with SD mounting in some cases.
I would suggest trying a different card and/or reprogram the V2 board with a different version of ProffieOS.
If none of that helps, then I would think there is something wrong with the V2 board.
Unfortunately my other SD cards are still on the way, but I’ll try flashing with an older version of proffieOS and report back. I appreciate the suggestion.
