Hello everyone,
I apologize in advance if I have not performed due diligence regarding solving my own issue, but the main issue is, I am on very limited time and am trying to program a saber for a friends gender reveal in less than 48 hours.
I have not used arduino or profile in quite some time, so there were many updates that needed to be completed. Upon completion, I began two receive an error message when trying to verify my existing config files, let alone making any updates to the config files.
Here is all copied text from the error message screen
Arduino: 1.8.13 (Mac OS X), Board: “Proffieboard V2, Serial, SDCARD (SPI), 80 MHz, half, Smallest Code”
/Users/Jason/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/…/lib/gcc/arm-none-eabi/14.2.1/…/…/…/…/arm-none-eabi/bin/ld:/Users/Jason/Library/Arduino15/packages/proffieboard/hardware/stm32l4/4.6.0/variants/STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region SRAM2' not declared lto-wrapper: warning: using serial compilation of 9 LTRANS jobs lto-wrapper: note: see the '-flto' option documentation for more information /Users/Jason/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld: warning: start of section .bss changed by 8 /Users/Jason/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld: ProffieOS7.15.ino.elf section .text’ will not fit in region FLASH' /Users/Jason/Library/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld: region FLASH’ overflowed by 9552 bytes
collect2: error: ld returned 1 exit status
Any help or recommendations are appreciated as I am pretty much down to the wire here trying to figure this out.
