I was finishing up an install, and to check my wiring was solid, I was putting together a test config with two presets, one with a font and one for battery charge. It’s got 7 blades (several sub blades) for accent pixels.
I shared a short video in the Proffieboard FB group, but when I go to boot it just beeps unendingly. It does not do this if I flash it back to default proffie config. I temporarily disconnected my negative leads to my accent pixels when troubleshooting because I initially thought it was a wiring thing. It’s not.
here’s my test config:
#define NUM_BLADES 7
#define NUM_BUTTONS 1
#define VOLUME 2400
#define CLASH_THRESHOLD_G 3.0
#define SAVE_STATE
#define FETT263_BATTLE_MODE
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_MULTI_PHASE
{ "QUI;common", "tracks/track1.wav",
/* main blade */
OS6.7 v4.017
This Style Contains 4 Unique Combinations
Base Style: Audio Rotoscope - Single Color (Original Trilogy)
Base Color: Rgb<0,255,0> (0)
Preon Effect: Sparking (Base Color)
Ignition Effect Options: Default (0): Standard Ignition, 1: SparkTip Ignition
Retraction Effect Options: Default (0): Standard Retraction, 1: Dual Mode Wipe In (Down = Fast)
LightningBlock Effect: Original Lightning Block
Melt Effect: Intensity Melt
Stab Effect: Normal Stab
Blast Effect (Randomly Selected): Responsive Blast Wave (Random), Responsive Blast Fade (Random), Responsive Blast Ripple
Clash Effect: Real Clash V1
Swing Effect: Force Boost Bright Swing (Scaled Full Blade)
StylePtr<Layers<AudioFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<10000>,TrFade<300>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<55,255,169>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<191,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Remap<CenterDistF<Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<IgnitionTime<0>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<0>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<0>,Mult<RetractionTime<0>,Int<16384>>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,3980>,Sum<IntArg<PREON_SIZE_ARG,3980>,Int<4000>>>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
/* emitter inner ring */
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Green>,Rgb<0,128,0>>,LockupTrL<BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,TrConcat<TrInstant,White,TrFade<300>>,TrFade<300>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<AlphaL<RgbArg<LB_COLOR_ARG,Red>,Int<0>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,BlastL<RgbArg<BLAST_COLOR_ARG,NavajoWhite>>,SimpleClashL<RgbArg<CLASH_COLOR_ARG,NavajoWhite>>,InOutTrL<TrInstant,TrFade<300>,TransitionLoop<Green,TrConcat<TrBoing<1200,2>,Rgb<0,10,0>,TrFade<1200>>>>>>(),
/* emitter outer ring */
StylePtr<Layers<TransitionLoop<Black,TrConcat<TrWipe<200>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,TrWipe<200>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_CLASH>,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrWipeIn<1000>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,TrWipeIn<1000>>>>>>(),
/* crystal chamber */
StylePtr<Layers<AudioFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,LockupTrL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrInstant,TrFade<1000>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,InOutTrL<TrInstant,TrInstant,TransitionLoop<RgbArg<OFF_COLOR_ARG,Rgb<108,255,0>>,TrConcat<TrBoing<1200,2>,Mix<Int<1285>,Black,RgbArg<OFF_COLOR_ARG,Rgb<108,255,0>>>,TrFade<1200>>>>>>(),
/* chassis strip upper */
StylePtr<Layers<TransitionLoop<Black,TrConcat<TrWipe<200>,RotateColorsX<Variation,DeepSkyBlue>,TrWipe<200>>>,InOutTrL<TrFade<500>,TrFade<500>,TransitionLoop<Black,TrConcat<TrWipeIn<1000>,RotateColorsX<Variation,Sparkle<Rgb<180,130,0>,White,150,1023>>,TrWipeIn<1000>>>>>>(),
/* chassis strip lower */
/* chassis center px */
StylePtr<InOutTr<White,TrInstant,TrInstant,ColorSequence<500,Blue,Cyan,Green>>>(),
"qui" },
{ "Battery;common", "tracks/SEAGULLS.wav",
/* main blade */
&style_charging,
&style_charging,
&style_charging,
&style_charging,
&style_charging,
"battery\nlevel"}
{ 0,
SubBlade(16, 127,WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >() ), /* main blade 32in (112px) */
SubBladeWithStride (0, 14, 2, NULL), /* emitter inner ring (8px) */
SubBladeWithStride (1, 15, 2, NULL), /* emitter outer ring (8px) */
WS281XBladePtr<4, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(), /* chassis crystal chamber (4px) */
SubBlade(0, 6, WS281XBladePtr<15, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5> >() ), /* chassis strip upper (7px) */
SubBladeReverse(14, 8, NULL), /* chassis strip lower (7px) */
SubBlade(7, 7, NULL), /* chassis strip center (1px) */
CONFIGARRAY(presets) },
edit: had wrong config pasted.
